Dimmer Curve
13 years 7 months ago #5817 by MarkThewessen
Dimmer Curve was created by MarkThewessen
I'm having trouble to customize the dimmer curve to let's say a non-dim dimmer curve.
How should i do that? I just seem to be able to choose from the standard curves.
Thanks in advance!
(i'm working on a Mac with version 3.0.12-b8)
13 years 7 months ago - 13 years 7 months ago #5822 by sl1200mk2
Replied by sl1200mk2 on topic Dimmer Curve
Hi Mark,
you can only play with registered curve, BUT there's a way to load data to draw the curve (I didn't test that from a long time, so I don't know if it's still working, you'll tell me...).
in the Patch->Curve window, the folder icon let you import curve.
you can import .cvs file wich i a set of data separated by comma.
(attached an example file)
you can generate this file with whatever software you like, but be careful, there's no error check.
can you test with a device attached to see if loaded curve works (or not)?
Last edit: 13 years 7 months ago by sl1200mk2. Reason: attachement
13 years 7 months ago #6016 by noelvd
Replied by noelvd on topic Dimmer Curve
Hello everyone,
I have tried this, and build a 'reverse lineair' (0=255, 1=254, ..., 254=1, 255=0) curve. [see attached]
The idea is to use this curve to reverse the movement (pan/tilt) of a mirror or moving head.
I could import the curve, but I will need to import it for each channel where I want to use this curve on.
Please note that I have not been able (yet) to test it live, to see if the head really turn the other way :P
@Nico, would it be possible to add this curve in DL as a standard ? Please ? Thanks !
Best regards,
Noël
B)
13 years 7 months ago #6019 by sl1200mk2
Noel,
nothing is attached...
please note that in the Patch window, if you select dimmer x thru y and hit curve, you'll work on all the selected dimmers.
so you can easily set a curve in one time for a pool of dimmer.
13 years 7 months ago - 13 years 7 months ago #6021 by noelvd
Oops... :ohmy:
Attachment Reverse_Linear.zip not found
Yes, I know about the pool, but the problem is that these pan/tilt channels are all over the place.
Thanks,
Noël
B)
Last edit: 13 years 7 months ago by noelvd. Reason: typo
13 years 7 months ago #6022 by sl1200mk2
Noel,
I won't set it for the 3.0.14 but I'll put it (in mathematical way) for the one after.
13 years 7 months ago #6023 by noelvd
NO hurry ;)
Thanks !
Noël
B)
13 years 1 month ago - 13 years 1 month ago #6806 by Wilf
Replied by Wilf on topic Dimmer Curve
I was just touching this topic because I need to have some non dim functionality. What I did:
1. change the curve to a non-standard curve. When you now select the map above you see that the dimmernumber has its own xml (i.e. when you change the curve of dimmer 3 to 'Static' there will be a "3-curve.xml" in the curves-map.).
When you open that xml (i had to unhide the folders in OSX via Terminal to do this) you see that Static has the name "curveType=5" which is logical because it's the sixth in the row (and one always start with 0).
What i did next is change everything greater than level id 127 to level 255 and I changed the curveType to 9 (this way it should be possible to get it in the dropdownmenu I thought). I saved it as "non dim.xml". I did not find a way to import it to the program yet so now it's just a solo file but one could use it as an importable curve anyway.
Last edit: 13 years 1 month ago by Wilf.
13 years 1 month ago - 13 years 1 month ago #6807 by Wilf
I tried to add the file but it didn't work. Trying again.
Attachment nondim.xml.zip not found
13 years 1 month ago #6808 by sl1200mk2
Hi,
Did you try the cvs way?
13 years 1 month ago - 13 years 1 month ago #6809 by Wilf
No not yet as I made the xml during a show week when I had no internet, so prior reading this topic. I thought "let's search on the forum" and saw this discussion so I thought I'd share it. I'll use the easier cvs file for more complicated dimmer curves next time, thanks. :)
p.s. is it possible to use csv to import a patch file too? Because I was thinking of making an iPhone app that makes it possible to patch during the time I'm on the stage filling in the light drawing of the venue. It's easier to make a csv than an xml.
13 years 4 weeks ago #6811 by sl1200mk2
@Wilf,
please try 10 as index. it's the one DL use for imported curve.
once you've modified the xml file of your desired curve, use the 'Folder' Icon to import the .xml file.
nope, but that's a good idea.
not for the 3.0.17 as I would to stop the beta phase to move to release one.
by the way, did you tried the latest layout I've made for DL (thanx to TouchOSC)?
it has Patch feature inside:
www.nicole-banana.com/index.php/forum/1-...e-for-iphone-android
13 years 4 weeks ago - 13 years 4 weeks ago #6813 by Wilf
sl1200mk2 wrote: @Wilf, please try 10 as index. it's the one DL use for imported curve.
Ok, thanks, I will.
sl1200mk2 wrote: by the way, did you tried the latest layout I've made for DL (thanx to TouchOSC)?
No not yet as I made a few TouchOSC-programs myself. I'll try yours this week, thanks!
Actually I see yours is for 3.0.17 and I am currently working with 3.0.14 (I'm a slow adopter to avoid bugs live) so I'll try it on my backup machine in the near future.
Last edit: 13 years 4 weeks ago by Wilf.
Time to create page: 0.169 seconds
