Que update in sequence jumps back to previous
13 years 8 months ago #5651 by vbs
Hi,
When i update a que that is more than one time in the sequence it jumps back to previous step.
So if que 2 is in step 2, 5 and 9.
when i am in step 9 and make some adjustment live in the (que2) as soon i update the que it will jump back to step 2.
This is not very handy if you are in a live show.
Is it posible to update this.
I am running DLight 3.11 on a Mac
Thanks Vincent
13 years 8 months ago #5654 by sl1200mk2
Replied by sl1200mk2 on topic Que update in sequence jumps back to previous
I come back to discuss that after 8pm
13 years 8 months ago #5656 by sl1200mk2
Vincent,
even if it's a feature of DL, I think it's not a very good practice to load a cue several times in the sequence.
thast said you're right, this algorythm can be improve.
what I can do is when you modify a cue (a cue that happen several time in the sequence), DL can look if this cue is in 'scene' or 'prepa' before starting a loop over all the sequence to find it.
your thought?
13 years 8 months ago #5657 by vbs
Thanks for your reply.
I am using DL for theater.
Sometime a same scene is coming back several time in a play.
To me it is logical that you copy or use that que several times instead of make all separate que's.
Unless i don't understand the way DL is designed?
Question--- is it possible that DL is not changing the step list ?
Best regards Vincent
13 years 8 months ago #5658 by sl1200mk2
I agree but the limit of that is that you cannot use the cue_goto function.
I do use this one a lot during rehearsal when we jump from scene to scene
I don't understand what you mean...
by the way, I've pushed code to detect if the modified/recorded cue is in X1/X2. if so, do not jump somewhere else.
and it's quite ok
13 years 8 months ago #5659 by vbs
If it not jumping to a other step while the update is done than i am very happy.
Wil this be in the next beta version ?
Thanks
13 years 8 months ago #5660 by sl1200mk2
yes, the b6 i'll publish tonight
13 years 8 months ago - 13 years 8 months ago #5661 by colinc
vbs wrote: Thanks for your reply.
I think that using a different cue for each step is very important if you use MIDI Show Control from another program to control DLight. For example, MSC refers to the Cue Number, not the step so if you use the same cue in many steps, an MSC command to 'GO' on cue 1 will always go the *first* instance of that cue' eg in Step 1.
Hope this helps
vbs wrote: Question--- is it possible that DL is not changing the step list ?
Last edit: 13 years 8 months ago by colinc. Reason: emphasis
13 years 8 months ago #5672 by vbs
Hi Nico
The problem i described above is gone in The Beta6 version.
THANKS !!!!!! :laugh: :laugh: :laugh:
Time to create page: 0.173 seconds
