INHIBITION FUNCTION
13 years 8 months ago #5488 by quico
INHIBITION FUNCTION was created by quico
Hi Nico,
Refered to de inhibit function:
A number of light controllers, allows the possibility to convert any Master in a Inhibition Master.
The way to use it is simple: the channel or channel-group that you charge on this submaster only can be lighted if you give to FF the level on this submaster.
This can be used to inhibit a device accidentally badly focused or as a way to prevent a not wanted switch-on of some device when you test the lamps.
The inhibit function created a cupel of releases ago is something like this but a little confused.
13 years 8 months ago #5489 by sl1200mk2
Replied by sl1200mk2 on topic INHIBITION FUNCTION
Hi Quico,
I've tried to merge a scale function with the inhibition function.
if you insert a channel in the inhibition editor, it's behaviour is rule by 2 law:
- if you give a level, the output of the channel is the % of recorded levels (if you set ch 1 at 90 in the inhib editor, the output will be 90% of recorded levels)
- if you set the level to FF, you access the inhibition point and there will be no output level for the channel.
hope it sounds clear.
13 years 8 months ago #5491 by quico
Replied by quico on topic INHIBITION FUNCTION
Hi again,
Je pense que cette limmitation du niveau d'un circuit peut meilleur se faire chez le patch, n'est ce pas?
13 years 8 months ago #5492 by quico
la raison d'avoir un Master d'Inhibition ou une fonction que povais convertir chaque master en un master d'inhibition c'est seulement que a havoir un accés assez rapide a la fonction.
13 years 8 months ago #5493 by sl1200mk2
c'est fonctions auraient effectivement pues se faire depuis le patch, en tout cas pour le scale, mais pour l'inhibition, l'idée de l'éditeur c'est effectivement d'avoir un accés rapide.
The following user(s) said Thank You: quico
13 years 8 months ago #5494 by quico
Merci enorme pour aider-nous et ton magnifique logiciel.
Salut!
13 years 8 months ago #5495 by sl1200mk2
thanx
Time to create page: 0.144 seconds
