INTEGRER UN FX A UN CUE
- efene
14 years 4 months ago #4799
by efene
INTEGRER UN FX A UN CUE was created by efene
Hello, complètement Novice dans D:Light, je ne trouve pas comment insérer un FX dans un Cue, merci
- colinc
- Thank you received: 22
14 years 4 months ago #4801
by colinc
Replied by colinc on topic Re: INTEGRER UN FX A UN CUE
Bonjour
S'il vous plaît excuser mon mauvais français, mais Google Translate est ... bien, parfois excentrique ...
Mettez votre FX sur un Sub, sélectionnez votre Sub (il doit avoir une ligne jaune autour de lui) et sur le numéro du pas de séquence que vous souhaitez que cela se produise, cliquez sur le bouton RLink
J'espère que cela vous aide
Cordialement,
Cordialement,
- efene
14 years 4 months ago #4802
by efene
Replied by efene on topic Re: INTEGRER UN FX A UN CUE
Where I must Select the sub? no yellow line
- colinc
14 years 4 months ago #4803
by colinc
Ok:
If you are in @Mode for the command line (just below the 'Sequence' panel), type the keyboard shortcut for 'Sub' then the number of the sub you have allocated your FX to, and press <Return> - the 'Level' box for that Sub number should get a yellow suuround
(If you type CTRL + 'K', (Mac: CMD ='K'?) it will list your keyboard shortcuts, including that for 'Sub')
If you are in RPN mode for the command line, *first* type the number of the Sub, *then* type the keyboard shortcut for 'Sub' and press <Return> - again, the 'Level' box for that Sub number should get a yellow suuround
Then click the 'RLink' button
Best wishes,
Ok:
Best wishes,
14 years 4 months ago #4808
Replied by sl1200mk2 on topic Re: INTEGRER UN FX A UN CUE
hi
Colin is right except that with the newest version of DL, you don't have to select submasters to use RLink function.
if there's no selected submasters, RLink will link every sub with a level to the active sequence's step.
if there's one or more selected submasters, RLink will link every selected sub to the active sequence's step.
this way, RLink is a very cool and fast function
Time to create page: 0.129 seconds
