About art-net configuration
- elsonoro
14 years 6 months ago - 14 years 6 months ago #4448
by elsonoro
About art-net configuration was created by elsonoro
Hello.
I have a ploblem with the Art.net configuration, and i don´t know what i´m doing bad.
I have a Art-net dmx (compulite eport-41) with ip. 10.0.0.2
my pc is a windows vista home premium ( i check to wiht a windws 7) my ip is 10.0.0.1 and sub red 255.0.0.0
note: if i do ping to 10.0.0.2 with cmd i see it
I start dlight / new show/ setup / dmx output select art net / edit / select 10.255.255.255 / click art-net discover
and don't show nothing
I see the wiki and the forum but i don't know what happen
thak you for your help
Last edit: 14 years 6 months ago by elsonoro.
14 years 6 months ago #4451
Replied by sl1200mk2 on topic Re: About art-net configuration
hi,
from the eport-41 spec:
otherwise, everything you did looks ok...
don't you have to setup your material to be able to receive Art-Net?Converting VC or Art-Net Ethernet protocols to DMX512
The following user(s) said Thank You: elsonoro
- elsonoro
14 years 6 months ago - 14 years 6 months ago #4456
by elsonoro
Replied by elsonoro on topic Re: About art-net configuration
Thank you for your rapid answer,
But i don't know what happen, I dissable windows firewall and antivirus.
I try with crossover cable and with router,
the program is runing how administrator.
the only think i see is that, when i click the art-net discover, the status of the red don´t change. don't send and returns any bit, it's normal?
14 years 6 months ago #4457
you don't need the crossover cable.
i make all my tests (with/without router) with straight cable, and it's fine
during this time, it send an ArtPoll request (nodes have 3 seconds to answer). if no one answer, it won't display any interface...
once again, are you sure the eport-41 is configured to receive ArtNet?
when you click on discover, it should display a 'wait for 3 seconds' message.the only think i see is that, when i click the art-net discover, the status of the red don´t change. don't send and returns any bit, it's normal?
Time to create page: 0.121 seconds
