Import LT program to d::light
  • guigelabert
14 years 7 months ago #4247 by guigelabert
Import LT program to d::light was created by guigelabert
Salut companys!
Could anybody explain me how can I import files from LT Lighting console?
I can save files as *.lt file and also as *.txt file (when I save as ASCII file), but not as *.asc.
Thank you very much
14 years 7 months ago #4248 by sl1200mk2
Replied by sl1200mk2 on topic Re: Import LT program to d::light
it should be possible, can you post a .zip of one example?
  • guigelabert
14 years 7 months ago #4249 by guigelabert
Replied by guigelabert on topic Re: Import LT program to d::light
Here you are!
I add an *.lt file and a *.txt file of the same show.
Those are the 2 possibilities I have in my console.
Thank you very much Nico.
:woohoo:
14 years 7 months ago - 14 years 7 months ago #4251 by dFVarela
Replied by dFVarela on topic Re: Import LT program to d::light
The *.txt file seems to be exactly like a ascii file just open it and save it as a *.asc file, that should do the trick!
If you are using windows do it whit notepad++ and not whit notepad!
dFVarela
Last edit: 14 years 7 months ago by dFVarela. Reason: I've converted it to *asc, try this attached file!
  • guigelabert
14 years 7 months ago #4252 by guigelabert
Thank you very much.
One last question: how can i convert it with Mac?
Thanks again.
14 years 7 months ago #4253 by sl1200mk2
@guigelabert,
on Mac, i use TextWrangler to edit all sort of text...
As Daniel mentioned, it looks like exactly .asc files. (he did for the job for ya man!!)
however, times are just mark as 'UP'. you won't have down times...
tell us how it goes,
  • guigelabert
14 years 7 months ago #4256 by guigelabert
Thank you very much, men!
I'll try and i'll tell you how it works.
14 years 7 months ago #4257 by dFVarela
That trick it's used between CONGO & MA LIGHTING, one uses *.asc files and the other uses *.alq, so chanching the extension it does the trick!
dFVarela
  • guigelabert
14 years 7 months ago #4270 by guigelabert
Hey everybody!
It works!!
It just don't respect the delay times, but I think it's usual in this kind of convertions, isn't it?
Thank you very much to all of you from Barcelona.
See you soon.
14 years 7 months ago #4273 by dFVarela
Yes, it is. When you import ASCII there are always times that don't work properly!
dFVarela
