DLight.sh
14 years 11 months ago #3415 by paucurses
DLight.sh was created by paucurses
Bonjour!
Sorry I do not know how to write in french. But I can read!
I've launched DLight.sh on the terminal as you say (sh /home/videopata/DLight-32-Linux/DLight.sh)and it came with an error:
"error while loading shared libraries: libXss.so.1: cannot open shared object file: No such file or directory"
I'm running Ubuntu 11.10 on a 32 bit computer and downloaded DLight-32-Linux (beta) and am new on linux universe.
What did I do wrong?
14 years 11 months ago #3418 by xlazarini
Replied by xlazarini on topic Re: DLight.sh
Try to right click on 'DLight.sh' go to properties, make it executable and then you just have to make a double click to run DLight, it seems that you're doing everything OK!
14 years 11 months ago #3424 by paucurses
Replied by paucurses on topic Re: DLight.sh
Thanks, dfvarela, for the tip. I've tried as you said and nothing happens. Even when I make it executable on the terminal (it seems that the terminal starts to open but it doesn't). Help!
14 years 11 months ago #3426 by sl1200mk2
Replied by sl1200mk2 on topic Re: DLight.sh
@video,
your system miss the libxss required by libxml2 provided within D::Light bundle.
it's strange because i use a linux distro 'out of the box', and never saw such a complain from the system.
on ubuntu, there's something called 'synaptic' or 'package manager' (i don't remember'...
make a search on this software for libxss or libxml2 (the later should install you the first) and install the lib.
after, try again to launch DL.
@daniel
todo bem ? ;-)
14 years 11 months ago #3433 by xlazarini
It is stange, I use TinyCore and had no problems running DLight, just needed to put libusb on boot!
If anyone is using TC tell me, i've made a .tcz file to launch DLight from the wbar!
@Nico:
Tudo bem, and you?
What Linux are you using?
14 years 11 months ago #3438 by sl1200mk2
@Daniel,
i use ubuntu, because it's simple to setup.
can you explain me what do you need to do on boot with libusb?
and please say hello to everybody at DM2 ;-), can't wait to come to see you again....
14 years 11 months ago #3461 by paucurses
@nico
SUPER!
I did what you said and it launched! libxss was in fact missising in the system. Then, my enttec usb pro run after autorizing the access of USB port as is told on WIKI.
And now i'm running a show!
Merci beaucoup!
@varela
Daniel Varela? D. Maria II?
Tudo bem?
Videopata aka Patinho.
Abraço (extensivo ao resto do pessoal)
14 years 11 months ago #3463 by sl1200mk2
@videopata
glad it works !!
13 years 11 months ago - 13 years 11 months ago #5203 by Orvalho
Replied by Orvalho on topic DLight.sh
Hi,
I downloaded the .tar file and untar it onto my desktop. Then I tried two ways to install it. The first one was the typical double click on the DLight.sh, execute it and aparently nothing happens, the second one was also the double click but then choosing the exec on the terminal and nothing happens again. What am I missing here? Do I have to do a "Make install" or a "./configure" of the file?
Best regards from Portugal
Last edit: 13 years 11 months ago by Orvalho.
13 years 11 months ago #5204 by sl1200mk2
Replied by sl1200mk2 on topic DLight.sh
@Orvalho,
you want to try:
sh /path/to/DLight.sh
(please adjust the /path/to to something real for your computer)
tell me how it goes.
The following user(s) said Thank You: Orvalho
13 years 11 months ago #5216 by Orvalho
@Nico, it worked! Thank you very much.
Regards
13 years 11 months ago #5217 by paucurses
I have not sent this message. What happens?
13 years 11 months ago #5218 by sl1200mk2
@paucurses,
nothing to worry...
I had crash the users database earlier this year, thread on the forum are recorded with a user ID, and as people are re-register, ID of former thread are wrong.
@Orvalho,
glad it works.
Time to create page: 0.170 seconds
