OSC fader move
il y a 5 ans 11 mois #20833 par loesSch
OSC fader move a été créé par loesSch
Hi, it's probably been written somewhere in this forum in French already.. sorry but my French is basically not existing.. I am trying to figure out what I can control with OSC in Dlight, so far so good but having issues to control submasters.. doesn't seem to work at all (works fine with midi) .. using the newest DLight and at the moment sending OSC from Qlab (/seq//X2LoadAndFireCue# works fine)
thanks
il y a 5 ans 11 mois #20834 par sl1200mk2
Réponse de sl1200mk2 sur le sujet OSC fader move
Hi,
the OSC page is here in the wiki:
getdlight.com/wiki/index.php/OSC#Syntaxe...n_4_.5B2018-02-01.5D
according to this page, the OSC message are:
/sub/x/level [0 to 255]
so for sub 1 at FF, you need to send:
sub/1/level 255
does that works for you?
Les utilisateur(s) suivant ont remercié: loesSch
il y a 5 ans 11 mois - il y a 5 ans 11 mois #20835 par loesSch
Réponse de loesSch sur le sujet OSC fader move
That's exactly what I tried (and all versions similar to it) :) but it doesn't work.. and if I listen to the OSC (with OSC_data_monitor) then I also get zero info when I move the faders..
Was working already from that list you suggested
il y a 5 ans 11 mois #20836 par sl1200mk2
ok,
may I ask you to test using the 4.1.14_rc2, please ?
(remove the previous one completely from /Applications _ trash it)
is it better?
il y a 5 ans 11 mois #20837 par loesSch
Perfect - now it works :)
il y a 5 ans 11 mois #20838 par sl1200mk2
cool,
thank you for your tests.
It also means I have to quickly publish 4.1.14....
Temps de génération de la page : 0.134 secondes
