Can't connect iphon osc with dlight
il y a 7 ans 9 mois #17757 par NachoL
Can't connect iphon osc with dlight a été créé par NachoL
I'm sorry, i'm quite new in the forum and i don't find a search tab, probably this thread is already commented.
I don't know what i do wrong, i follow all steps but my iphone doesn´t connect with the Dlight, can somebody help me to see what am I missing?
I have d::light 4.0.24, mac osx 10.13.5 and iphhone with os12.1.2
Thank you
il y a 7 ans 9 mois #17758 par aroom
Réponse de aroom sur le sujet Can't connect iphon osc with dlight
Hi
Did you check the wiki?
Les utilisateur(s) suivant ont remercié: NachoL
il y a 7 ans 9 mois #17759 par NachoL
Réponse de NachoL sur le sujet Can't connect iphon osc with dlight
Yes, i followed all instructions. I think is something i do wrong about the wifi. I’lll try to put pictures of my steps to see if you can help me. Thank you
il y a 7 ans 9 mois #17760 par aroom
That being said the search tab is the last tab on the right. You’ll find some thread about osc who could help you.
il y a 7 ans 9 mois #17761 par NachoL
this is what i tried, and i get not connection
...i tried to search the forum but unluckily my french is not enough
Thanx
il y a 7 ans 9 mois #17762 par NachoL
This is what i tried in dlight
il y a 7 ans 9 mois #17763 par NachoL
sorry, i hope now
il y a 7 ans 9 mois #17770 par aroom
I don’t see the IP adress from your Mac. Make sure you setup the right adress in both your phone and dlight
Just setup one up adress in dlight, the one from your smartphone
Don’t use osc bridge if your not using it. Turn it off.
Really re check the wiki. You can translate to in Spanish with google translate.
il y a 7 ans 9 mois #17773 par NachoL
Got it!!! Merci encore
il y a 7 ans 9 mois #17774 par sl1200mk2
Réponse de sl1200mk2 sur le sujet Can't connect iphon osc with dlight
Hi,
Can you please explain what was wrong, or how do you sorted out?
il y a 7 ans 9 mois #17775 par NachoL
Réponse de NachoL sur le sujet Can't connect iphone osc with dlight
I disabled touch bridge, set the adress port in DLight to match wifi IP from the wifi page in iphone settings (not the IP that appears in touch osc, wich is a different number and confused me) now works fine
il y a 7 ans 9 mois #17779 par sl1200mk2
thank you for the explanations
Temps de génération de la page : 0.213 secondes
