- Remerciements reçus 1074
touchOSC hacking 4 Android
if you try this, would you mind report your results....
- dFVarela
- Remerciements reçus 5
dFVarela
- dFVarela
I'll have to continue using Control! When a new dlPad.js?For some reason the Android version of TouchOSC doesn’t support Labels, so if you add them in your layout and use this workaround to load it, your whole layout will just be black and unusable.
dFVarela
thxx for testing this... it's a shame it does not work...
did you see the one Colin wrote?I'll have to continue using Control! When a new dlPad.js?
i use it and it's good. his dlPad.js reside on the dlight-tools github.
- dFVarela
The one under: dlight-pad / control / dlPad.js?did you see the one Colin wrote?
It is the one i'm using but is missing things like 'GoBack', and so on...... But it works, focused everything today with it!
dFVarela
- colinc
- Remerciements reçus 22
dfvarela écrit: It's a TouchOSC problem....
My version does have GoBack - and Pause, Blackout, Live (scene) and Blind ( prepas), and a whole separate page with 10 submasters. But it's a fork from Nico's so he will have to pull it, or I will try to attach it here
La pièce jointe Control_dlPadfile_2012-09-14-2.zip est absente ou indisponible
any idea of how to merge from your fork ?
- colinc
(see also the other dlPad thread, where I've posted the same)
I have sent you a 'Pull Request' from my GitHub fork. If you go to the 'Help' tab on the GitHub pages, there is a section on 'Pull Requests, and also how you respond to the request, review my fork, and then the commands to issue to merge my fork into your repository.
My fork for the Merge command is 'github.com/colinctoo/dlight-pad'
Regards
