- Remerciements reçus 958
dlight-tools
- Administrateur
i've tested your interface, great job
hour widget works on every page, Menu button also, etc...
the button near Menu is used to reload interface. I think it's ok on the first page, but is it necessary on the other one...
also, about the submaster page:
maybe submasters can be less large, like that we can imagine to have button on the top to :
'kill all open sub'
'switch page'
'switch subbook'
if you work on these commands, please tell me and i can code output message on the DL side.
also, would you mind teach me how to merge your master to dl-tools master ?
all the best,
- colinc
- Membre elite
- Remerciements reçus 22
sl1200mk2 écrit: hello Colin,
Glad you approve...
sl1200mk2 écrit: the button near Menu is used to reload interface. I think it's ok on the first page, but is it necessary on the other one...
That button's space occurs on every page, as a Page Title - so why not also keep the refresh button under it on each page. That way, the space is not wasted? But if you can think of a better use, I'll gladly think on it...
sl1200mk2 écrit: also, about the submaster page:
I'd prefer Buttons below (beside the Down/Up buttons)
sl1200mk2 écrit: 'kill all open sub'
Yup, good idea
sl1200mk2 écrit: 'switch page'
Aahh... But then I think you'd need Control to be able to read back an OSC message telling you which page you're on (which I don't think it can, because you could qickly forget and get lost). My own thought was simply to add a few more Sub pages to the file
sl1200mk2 écrit: 'switch subbook'
Yup
sl1200mk2 écrit: if you work on these commands, please tell me and i can code output message on the DL side.
I can put the buttons in very easily, then all you do is tell me what the OSC message to go into them is
sl1200mk2 écrit: also, would you mind teach me how to merge your master to dl-tools master ?
I'll figure it out and get back to you
Regards
- Administrateur
IMHO the best is to use the OSC monitor software you have and bind it to DL OSC writer in order to see what command is available and what commands are missing when you move submasters, change sub pages, sub book or hit kill sub button.
Nico
- colinc
- Membre elite
'kill all open sub'
You will need to code a /sub/killall OSC message. At the moment, when you press the Kill Subs button, the OSC output is a series of /sub/#/level commands - not feasible to code this in a 'Control' button
'switch page'
You will need to code a /sub/next and /sub/previous OSC command - At the moment, when you select the Subpage number you want, the OSC output is a series of /sub/#/level commands followed by a /sub/page # - again, not feasible to code this in a 'Control' button
'switch subbook'
No command at all, but as Sub Page switch needed
all the best,
- Administrateur
thanx for that, i think i can include them in the 3.0.10 release (I won't publish another beta as i need to move on...)
okYou will need to code a /sub/killall OSC message. At the moment, when you press the Kill Subs button, the OSC output is a series of /sub/#/level commands - not feasible to code this in a 'Control' button
you'll need to adapt the OSC.Manager of control to process the /sub/x/level
can't you extract the # of /sub/page ?You will need to code a /sub/next and /sub/previous OSC command - At the moment, when you select the Subpage number you want, the OSC output is a series of /sub/#/level commands followed by a /sub/page # - again, not feasible to code this in a 'Control' button
i think that previous/next isn't so easy to maintain up to date
okNo command at all, but as Sub Page switch needed'switch subbook'
- Administrateur
for the 3.0.10 i've added
/sub/kill 1 (when kill open submaster is invoke)
/sub/book x (where x is the subbook to be processed)
