- Remerciements reçus 1
Serial Communication Enttec
- p.leijstra
il y a 13 ans 7 mois #5705
par p.leijstra
Serial Communication Enttec a été créé par p.leijstra
Hi,
I have a simple question, and also hope there is a simple answer. But maybe someone can help me with some simple knowledge:
How does
:light communicate with the Enttec? I know it's serial communication via the libusbx driver, but what kind of data is send? Is it just an bytearray with DMX values?
Hope someone can clear this up.
Thanks in advance.
Piet
How does
:light communicate with the Enttec? I know it's serial communication via the libusbx driver, but what kind of data is send? Is it just an bytearray with DMX values?Hope someone can clear this up.
Thanks in advance.
Piet
- Remerciements reçus 1074
il y a 13 ans 7 mois #5713
Réponse de sl1200mk2 sur le sujet Serial Communication Enttec
Hi Piet,
the array is prepended with start code, label and some length info, and at the end, the End code is appended
hope this helps,
exactly, at the end of Sub/channel/curve/grandMaster/everything merge, I fill an unsigned char arry with dmx values I want to send to the usbPro (or everything that is usb/dmx).How does
hope this helps,
- p.leijstra
il y a 13 ans 7 mois #5718
par p.leijstra
Réponse de p.leijstra sur le sujet Serial Communication Enttec
Hi,
Yess this really helps! Could you explain more about the start/end code and the label? is start and end that hex e7 used in the Enttec document? What label number do you use to send dmx values?
thanks allot!
thanks allot!
il y a 13 ans 7 mois #5724
start is 0x7E
end is 0xE7
label for sending is 6 (SET_DMX_TX_MODE)
end is 0xE7
- p.leijstra
il y a 13 ans 7 mois #5725
par p.leijstra
HI, Thnx allot! I used a serial monitor to what a packet looks like (from d::light to enttec) this is wat i get:
7E 06 01 02 00 66 00 00 00 00 00 00 00 00 00 00 00 FE 7F
00 00 7F FE 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 E7
The 7e and e7 are the start and end, the 06 is the label. Are the 01 and 02 the length info?
So if I would like to send commands from flash to the dongle, this is what i have to send right?
Your a really great help!
Thnx,
Piet
00 00 00 00 E7
Thnx,
Piet
Les utilisateur(s) suivant ont remercié: colinc
Temps de génération de la page : 0.149 secondes
