- Remerciements reçus 1074
No USB DMX Pro found
merci de lire le wiki (et me dire si c'est assez clair)
www.nicole-banana.com/index.php?option=com_jwiki&Itemid=14
- bolderouille
- bolderouille
- bolderouille
attention a installer aussi les drivers de bases et le Vcom pour ceux qui ont Xp et ajouter en plus le Zadig. Reste plus qu'a avoir la main sur les light
t'es sûr qu'il faut installer les VCOM au préalable ???? normalement zadig se charge d'installer les librairies et drivers nécessaires à la libusb.
- bolderouille
Merci pour ta futur solution
qu'est-ce qu'il se passe si tu branches ton boitier et que tu lances zadig.exe ?
- xlazarini
I'm trying to connect the USB PRO, but when I launch zadig.exe all the fields are blank.
Then I go to:OPTIONS and click LIST ALL DEVICES, then it appears:
-USB SERIAL CONVERTER
-USB VIDEO DEVICE(INTERFACE 0)(INTERFACE 0)(INTERFACE 0)(INTERFACE 0)(INTERFACE 0)
But when I install the drivers even the PRO UTILITY don't connect whit DMX PRO, I have to install the drivers again!
This is on Win VISTA, and it disabled some of ACER software that was installed by factory default!
can you try to launch zadig.exe with the usb dmx pro plugged.
it should show FT245BM or something similar.
- xlazarini
It's recognized as : USB SERIAL Converter
VID:0403 PID:6001
When I install libusb0(1.2.4.0) it not recognized anymore, same thing with libusbK(3.0.1.18) either by DL 3.0.5,DL 3.0.6 or by the ENTTEC Utility!
I install the CDM20802 and it's recognized by the ENNTEC Utility but not by DL3.0.5 or by 3.0.6!
i think it'll be a mess ....
i tried the code with my pc laptop (running win7) and it was working great (also some people reported it was ok), that's why i decided to move to libusb despite extra downloading it requires (only zadig.exe).
VID & PID are ok, they are those used by FT245BMIt's recognized as : USB SERIAL Converter
VID:0403 PID:6001
but after you do not need to install libusb , libusbK and friends...
libusb is included in DL_installer and copy the dll to installation folder.
does zadig tell you to install libusb ? (normally it should install libwdi
sourceforge.net/apps/mediawiki/libwdi/index.php?title=Main_Page )
please try to uninstall stuff and do it again!
ate la proxima
- xlazarini
GOT IT......
The way i found to solve it:
-Connect DMX USB PRO
-Open device manager, find USB SERIAL CONVERTER, Right Click and select UNISTALL
-Open ZADIG.EXE, go to OPTIONS and select LIST ALL DEVICES
-Select USB SERIAL CONVERTER
-Click on INSTALL DRIVER
Thanks for the tip:
Hope that this can help others whit that other OS!
The problems I had whit ACER software disabled was due to ENTTEC UTILITY, simply solved whit a SISTEM RECOVERY!
Até á próxima!
- aurel
J'ai le même problème que vous, quelqu'un à su résoudre ce problème au final, car je ne pige rien !!
Merci à vous
