- Remerciements reçus 1
Arhtnet don't concect windows Xp
- vbs
il y a 11 ans 11 mois #8821
par vbs
Arhtnet don't concect windows Xp a été créé par vbs
I am trying to connect a Entec node to Dlight runing windows Xp.
It is recovering the node but if i start the server it shows waiting for 3 seconds but nothing happens.
Any idee??
Regards Vincent
Any idee??
Regards Vincent
il y a 11 ans 11 mois #8826
par aroom
Réponse de aroom sur le sujet Arhtnet don't concect windows Xp
check the ip adress of your node. you may have to switch the "BroadCast ArtPoll" from 255.255.255.255 to 10.255.255.255 or 2.255.255.255
check you firewall
check that both ip adresse from the node and from the computer are different
check you firewall
il y a 11 ans 11 mois #8833
Réponse de sl1200mk2 sur le sujet Arhtnet don't concect windows Xp
Hi,
for example:
computer: 10.0.0.50 (submask 255.0.0.0)
node: 10.0.0.51 (submask 255.0.0.0)
computer: 192.168.1.50 (submask 255.255.255.0)
node: 192.143.200.20 (submask 255.255.255.0)
(this one is not defined by artNet draft that specify 10.x.x.x/2.x.x.x IP range, but it works)
also don't forget to select 'available' at node level before starting the artNet server.
that's true but keep in mind that both computer and node address must be on the same IP range.check that both ip adresse from the node and from the computer are different
for example:
- vbs
il y a 11 ans 11 mois #8841
par vbs
Réponse de vbs sur le sujet Arhtnet don't concect windows Xp
Hi
Thanks for your reply.
Putting the ip adres in the Same range works, thanks
Recards Vincent
Recards Vincent
Temps de génération de la page : 0.131 secondes
