Export Dlight to LT Hydra II
il y a 3 ans 6 mois #24805 par mjodar
Export Dlight to LT Hydra II a été créé par mjodar
Hi Nico,
I have a show programed on DLight that I need to export to an LT console.
Apart from the obvious problems that I will need to check and correct manually (time Outs not loading, wait times not loading.... not a big deal. Will do manually)
DEVICES:
On that show I have 4 devices programmed (4 LED bar strips) on D-Patch 41,42,43,44. When I export the ASCII file, on the sequence, it only appears the Device channel (CH 41 @50, for example, which only affects the dimmer channel). Is there a way on DLight i can convert the Devices to normal Channels?
So i can see the values for every channel of the device on every Cue.
For example, if i have programmed a CYAN at 50% dimmer, convert it back to:
D  R   G   B   W
50 0 100 100 0
(does it makes sense what I'm saying?)
CHASES:
Is there a way to convert all the Chases made on DLight, so the LT can load them? I have like 20 diferent Chases, if I can avoid to re-program all of them manually.
Thanks a lot!!
marc
il y a 3 ans 6 mois #24808 par sl1200mk2
Réponse de sl1200mk2 sur le sujet Export Dlight to LT Hydra II
Hi,
there's no way to export Device's stuff to ascii...
Ascii is an unfinished (and some manufacturer have decided to unfinish it) standard...
Temps de génération de la page : 0.115 secondes
