Control DLight with QLab: MIDI or OSC?
- mjodar
il y a 4 ans 1 mois #23630
par mjodar
marc
Control DLight with QLab: MIDI or OSC? a été créé par mjodar
Hi all,
That may be a stupid question, but if I want to control Dlight with Qlab, what is better, safer, more reliable...? Midi or OSC?
Both softwares are on the same machine. So I'm talking on using MIDI over IAC, or OSC over localhost.
I've done lots of shows with QLab firing Dlight over MIDI, and never had any problem. But I was just wondering if OSC may be more reliable?
Thanks!
Thanks!
marc
il y a 4 ans 1 mois - il y a 4 ans 1 mois #23631
par aroom
Réponse de aroom sur le sujet Control DLight with QLab: MIDI or OSC?
I like OSC better.
I don't know if it's safer or more reliable. But I find the syntax of OSC address more intuitive to program and the network aspect faster to setup.
to fire Cue 1
to fire ID 1.1
to fade Submaster 1 (you'll need to change the fade option to 1D fade in QLab and set-up the duration and From and To amount)
You have to keep in mind that QLab is using the local language preferences from macOS to decide how decimal are being used (System Preferences/Language and Region/General Advanced General Decimal). you gonna have to check if it's a dot or a coma. I strongly advice anyone to go for the dot.
In my macOS, the decimal is a point. If your system is using the coma, the OSC message may not work properly. You'll have to manually change all the . for , or to change your macOS preferences, or to use a script to do it automatically.
to fire Cue 1
Code:
/seq/X2LoadAndFireCue 1
to fire ID 1.1
Code:
/seq/X2LoadAndFireID 1.1
Code:
/sub/1/level #v#
- mjodar
il y a 4 ans 1 mois #23632
par mjodar
marc
Réponse de mjodar sur le sujet Control DLight with QLab: MIDI or OSC?
Yes, that's what I thought. I think Network would be faster.
I was literally right now programing a show, and using the /sub/1/level #v#to do some flashes at the rythm of the music, to make some LEDs flash as if they were incandescent lights
marc
- Remerciements reçus 1074
il y a 4 ans 1 mois #23637
Réponse de sl1200mk2 sur le sujet Control DLight with QLab: MIDI or OSC?
Hi,
as @Aroom said, you'll always want to prefer OSC over Midi
Les utilisateur(s) suivant ont remercié: mjodar
- mjodar
Temps de génération de la page : 0.138 secondes
