QLAB + DL
- grifu
il y a 14 ans 8 mois #4119
par grifu
QLAB + DL a été créé par grifu
We are using an application called Qlab for the control of the operations sending midi messages to Dlight for remote control using step forward, but when in rehearsal it would be nice to jump to a certain cue. I would like to send via midi the cue number to trigger Dlight, do you think it's possible ?
i also tried to use Midi Show Control Message from QLAB using the MSC operation with different command format (e.g. Lighting) and different Command messages (e.g. GO, SEQUENCE_+) sending to the Device ID: 1 with Q Number X to jump to certain cue in D:light. In D:light i´ve setup the midi device and input.
Notice: the midi note control from QLAB to step+ or step- in D:light works perfect.So there is no problem with midi connection from QLAB to D:Light.
What kind of message should i send from Qlab to control the cue number at D:Light ?
thanks in advance..
Grifu
thanks in advance..
Grifu
- Remerciements reçus 1074
il y a 14 ans 8 mois #4120
Réponse de sl1200mk2 sur le sujet Re: QLAB + DL
hi,
in the QLab side, set a step with MSC
in the 'Midi Show Control Messages' tab (at the bottom we you've selected the MSC) you must set
IAC Bus as output patch
All types in Command Format
GO as command and fill the same ID as you've set in
:Light
in Q number, fill with the desired
:Light cue number (the cue, not the step)
on the
:light side, make sure you've set the Midi Input to the same as the Output patch you've set in QLab (you can also select 'Mutliple Input'
and that's all.
:Lightin Q number, fill with the desired
:Light cue number (the cue, not the step)on the
:light side, make sure you've set the Midi Input to the same as the Output patch you've set in QLab (you can also select 'Mutliple Input'and that's all.
Les utilisateur(s) suivant ont remercié: yvan bonnin
- grifu
il y a 14 ans 8 mois #4125
par grifu
Réponse de grifu sur le sujet Re: QLAB + DL
Thanks for the quick response.
Its working now, i believe that my mistake was that i didn´t had any cue in the sequence
by the way, as Output patch i´m using a virtual midi machine called midi patchbay which enables the creation of any input and output midi for rewiring.
Your app is amazing, keep the good work.
thanks again.
Grifu
thanks again.
Grifu
- yvan bonnin
il y a 13 ans 3 mois - il y a 13 ans 3 mois #6614
par yvan bonnin
Réponse de yvan bonnin sur le sujet Re: QLAB + DL
bonjour
je me lance dans le contrôle de DL via d'autre soft (Qlad et Live)
je viens de lire l'ensemble du sujet mais ça ne fonctionne pas chez moi.
j'ai pourtant :
- activé le Gestionnaire IAC dans la conf midi du mac (macbookpro)
- patché dans Qlab le patch 1 sur Gestionnaire IAC
j'ai bien dans mon évènement MSC
output patch : Gestionnaire IAC bus1
command format : all Types
command : SEQUENCE_+
device id : 1
et dans DL j'ai bien sûr activé le midi avec sur midi input et output : Gestionnaire IAC Bus1
Midi show control : 1
mais rien ne se passe quand je fait espace sur Qlab et que le MSC se lit.
merci de me corriger car j'ai dut faire une erreur quelques part mais je ne la vois pas
edit j'ai oublié de spécifier ma version de DL ^^ 3.0.8-B1
j'ai pourtant :
device id : 1
- yvan bonnin
il y a 13 ans 3 mois #6616
par yvan bonnin
c'était juste ça ! ça fonctionne avec le GO et la conf ci-dessus.
Merci pour ton retour. il faut que je cherche à faire la même manip avec Live maintenant. y a t'il un post déjà ouvert là dessus ?
cool le retour rapide, toujours autant agréable
Réponse de yvan bonnin sur le sujet QLAB + DL
sl1200mk2 écrit: hello,
seul le message GO fonctionne en MSC.
si il en faut d'autre, merci de les lister et je les mettrais.
Temps de génération de la page : 0.151 secondes
