4.0.29_b4
il y a 7 ans 8 mois #18023 par sl1200mk2
4.0.29_b4 a été créé par sl1200mk2
revert from bad code...
il y a 7 ans 8 mois #18024 par dFVarela
Réponse de dFVarela sur le sujet 4.0.29_b4
Still crashes when trying to clone a device!
dFVarela
il y a 7 ans 8 mois #18025 par sl1200mk2
Réponse de sl1200mk2 sur le sujet 4.0.29_b4
hmmm,
can you post you sho and tell me how many devices you want to clone and starting from which channel.
il y a 7 ans 8 mois - il y a 7 ans 8 mois #18026 par dFVarela
I was creating a new show! After saving it clone works OK!
I'll try again just to check and report!
Edit: It crashes if trying to clone when the show is not saved!
dFVarela
il y a 7 ans 8 mois #18027 par sl1200mk2
and which personality are you using?
il y a 7 ans 8 mois #18028 par dFVarela
This one that i've created:
Fichier en pièce jointe :
Nom du fichier : ETC_ColorSource.dld
Taille du ficher :1.16 Ko
dFVarela
il y a 7 ans 8 mois #18029 par sl1200mk2
can you send it to me on my email, I don't know why here it doesn't works.
thanks
il y a 7 ans 8 mois #18030 par sl1200mk2
you may have spotted something... cloning while sho is not saved...
will check that
il y a 7 ans 8 mois - il y a 7 ans 8 mois #18031 par dFVarela
Send it!
It only crashes when you start DL and make new show, if you open a saved show first and then create a new one it's OK!
dFVarela
il y a 7 ans 8 mois #18033 par dFVarela
One more thing:
If you have a device selected and press [ESC] it closes the DB and deselects the channel(s).
dFVarela
il y a 7 ans 8 mois #18038 par sl1200mk2
@Daniel,
that's expected... would you prefer it close the DB but do not deselect the channel?
regarding the clone crash, I still don't succeed to reproduce it.
It may have something to do with your hard drive structure...
can you open cmd.exe (I guess you know how to find it)
type :
SET | more
type Enter till you got the whole stuff
can you copy/paste the whole stuff and send me an email ?
thanks
il y a 7 ans 8 mois #18039 par dFVarela
Hi Nico,
I've send it already!
It only happens when i run DL and make a new show, if i open an existing one first everything is OK!
No it's OK like it is,but didn't know if that was the expected!
dFVarela
il y a 7 ans 8 mois #18040 par sl1200mk2
b5 is online
Temps de génération de la page : 0.178 secondes
