pre 4.0.5
il y a 9 ans 9 mois - il y a 9 ans 9 mois #14116 par sl1200mk2
pre 4.0.5 a été créé par sl1200mk2
This release will introduce microPalette.
what is a microPalette????
microPalette handle one or several parameter(s) defined in the personality of a device, and only operate on a specific range defined by the user.
microPalette are loaded in submasters and are executed in an exclusive mode for all selected devices that are registered within the submaster.
for example, let's say devices are lighting ON with shutter open.
you record a microPalette for SHUTTER parameter on the range 4 -> 128 that you load on submaster 1.
when you'll open sub1, the shutter will start strobing form low to fast (if in the personality strobing form low to fast is registered in the range 4 -> 128).
when you shutdown the submaster, the shutter will return to it's open state.
it'll be veeeeeery useful for gigs :)
- address patch issue when user use Shift key to extand selection for outputs
- bug fixes and code cleaning
Temps de génération de la page : 0.109 secondes
