pre 4.0.0_b67
il y a 10 ans 5 mois - il y a 10 ans 5 mois #12680 par sl1200mk2
pre 4.0.0_b67 a été créé par sl1200mk2
FWIW, I've decided to clean OSC reader/writer messenger before the final release (and this is not a good news for you... :( )
I've changed:
/circ/level x y (where x is the channel, y the level)
/circ/prepalevel x y
/sub/text x blabla
/sub/level x y
/sub/flash x y
/sub/phase x y.y
all the /subStick messages and also the /device ones
for the devices it looks like
/device s i i (string (/attribut/parameter), int (device numbr), int (value))
I know that all your pd patchs, touchOSC stuff, etc... won't work anymore
but it gain clarity and parsing efficiency.
happy hacking B)
il y a 10 ans 5 mois #12727 par sl1200mk2
Réponse de sl1200mk2 sur le sujet pre 4.0.0_b67
also,
-added support for usb pro mk2 (revB)
-added wait times to chaser editor $:-)
il y a 10 ans 4 mois #12766 par vbs
Réponse de vbs sur le sujet pre 4.0.0_b67
I am confused about the change you made in OSC
for instance my submaster 1 use to be;
/subStick/1/level
and submaster 1 tekst;
/subStick/4/text
Should i change this in
/sub/text/1/x
/sub/text/1/y
Records Vincent
il y a 10 ans 4 mois #12767 par sl1200mk2
Hi Vincent,
/subStick/1/level
/subStick/4/text
now you should use:
/subStick/level 1 xxx (where xxx is the level)
/subStick/text 4 yourTextAsTheSecondArgument
il y a 10 ans 4 mois #12768 par sl1200mk2
Vincent,
touchOSC does not seem able to handle yet multiple argumentation.
I wrote them in order to ask for this feature, and I guess the more we will wrote to them, the more we will get a chance for this feature to be coded...
I realize that for now we don't have a solution until touchOSC update their code....
please ask them to allow multiple argumentation for sliders/buttons/labels/etc....
the correct sentence is:
/subStick/level x yourText
with a space between level and x and between x and yourText
this is the multiple argumentation
il y a 10 ans 4 mois #12770 par celio
Réponse de celio sur le sujet pre 4.0.0_b67
Coucou Nico.
Pas sûr de bien comprendre ce que tu entends par xxx si The level (on met du coup la valeur maxi ?)
Pour yourText meme genre de question...
En tout cas je comprends que touchosc ne gère pas la multiple argumentation. Par contre si j'arrivais à comprendre mieux (je ne désespère pas) la nouvelle syntaxe je peux peut être créer un Patch isadora qui lui pourra renvoyer l'info en multi transmit il gère ca a priori.
A plus. Célio.
il y a 10 ans 4 mois #12771 par sl1200mk2
@Celio
tu donnes comme premier argument le numéro du sub/circuit/subStick que tu veux controler
en deuxième argument la valeur
dans l'exmple précédent, si je veux le sub 6 à FF j'écris:
/subStick/level 6 255
et si je veux le sub 6 à 50% j'écris:
/subStick/level 6 127
il y a 10 ans 4 mois #12772 par celio
C'est bien ce que je pensais Nico, ce que je ne comprends pas c'est que écrire une valeur type 255 ou 127, je le comprends si je veux envoyer une valeur fixe. Mais si c'est un fadeur qui envoie l'info ? Comment cela se traduirait il si touchosc gérait la multiple argumentation ?
C'est peut-être complètement con comme question et je m'en excuse :)
A plus. Célio.
il y a 10 ans 4 mois #12773 par sl1200mk2
@celio
dans ton touchOSC tu vas écrire pour chaque slider:
/subStick/level x (ou x est le numéro du stick) et tu vas laisser touchOSC ajouter la valeur du slider comme deuxième argument.
si tu fais du pureData, tu fais pareil... le premier argument est le numéro du sub que tu veux piloter, le deuxième la valeur que tu veux lui donner.
mais toi tu fais du isadora... B)
mais ça doit etre pareil.
il y a 10 ans 4 mois #12774 par sl1200mk2
par exemple, le fichier ci-joint commanderait le sub 1 de 0 à 255
il y a 10 ans 4 mois #12775 par sl1200mk2
oups...
Fichier en pièce jointe :
Nom du fichier : multiArg_E...touchosc
Taille du ficher :389 o
il y a 10 ans 4 mois #12776 par Jefff
Réponse de Jefff sur le sujet pre 4.0.0_b67
@Nico :
J'ai l'impression que le texte dans le champ des subs ne reste pas après avoir changé de page de sub et en revenant dessus.
il y a 10 ans 4 mois #12777 par sl1200mk2
@Jeff,
6 u on IRC ;-)
Temps de génération de la page : 0.167 secondes
