4.0.0_b37
il y a 11 ans 5 mois #10013 par sl1200mk2
Réponse de sl1200mk2 sur le sujet 4.0.0_b37
Hi guys,
@Wilf
we have to figure out how to find a decent solution within the patch window.
keeping only patch means for me less work to maintain everything on the top...
So at some point in the future, I'll add name for channels in the patch window
@antoine
ok, je vais checker ça
thanx
il y a 11 ans 5 mois #10014 par Wilf
Réponse de Wilf sur le sujet 4.0.0_b37
Merci Nico, je comprendre. :)
il y a 11 ans 5 mois #10021 par sl1200mk2
b38 is up
il y a 11 ans 5 mois #10022 par Wilf
I got a program crash seconds after patching 1 @ 4 [+] 5 [+] 10
il y a 11 ans 5 mois #10024 par sl1200mk2
@wilf,
ok,
were you in channel first or dimmer first?
il y a 11 ans 5 mois #10025 par Wilf
Channel first, just after opening a show, I wanted to demonstrate the patch to a technical friend who uses Dlight3
il y a 11 ans 5 mois #10026 par sl1200mk2
it's a shame....
will fix,
thanx for reporting
il y a 11 ans 5 mois #10028 par sl1200mk2
@Wilf,
would you mind trying the patch stuff with the 4.0.0_b38, please?
il y a 11 ans 5 mois #10029 par Wilf
I'll test b38 pre show tomorrow (& run with 3.23 as always).
il y a 11 ans 5 mois #10030 par sl1200mk2
@Wilf
despite many tries, I cannot reproduce the bug...
what platform/OS version do you use?
il y a 11 ans 5 mois #10031 par Wilf
MacOS 10.9.5 with Enttec Pro 2, X11 2.7.7, Dlight 4.0.0.b37 for X9.
I did not look into it after crash (did not try to replicate error) since I had my show to patch. I closed 4 and opened 3 to work as usual.
Could it be because of a differences in interpretation of data in my show file made in 3()23..?
il y a 11 ans 5 mois #10032 par Wilf
I'll try b38 this afternoon.
il y a 11 ans 5 mois #10033 par sl1200mk2
@wilf,
yes
can you please post your 3023 show?
il y a 11 ans 5 mois #10034 par Wilf
Here's my show. I've prepatched a strobo and smoke machine in it, on both available universes, so they always work, regardless of using house line or second line.
Fichier en pièce jointe :
Nom du fichier : Kusjeerop7.sho
Taille du ficher :44.99 Ko
il y a 11 ans 5 mois #10035 par sl1200mk2
@Wilf
yeah!! that a good show to work with ;-)
everything inhibed, chaze, speed master, TLink, Mlink.... almost everything :-) (Devices are missing....)
well, it crashes here too, so I'll be able to fix it
thanks
