Device personality
il y a 11 ans 7 mois #9560 par Bestia Humana
Device personality a été créé par Bestia Humana
Hi to everyone.
This is the Martin Rush Par 2 RGBW Zoom personality.
Checked on stage. Dimmer fine is in EXTRA to control that.
Enjoy it
edu
Les utilisateur(s) suivant ont remercié: labelbrut, Rylabellevie
il y a 11 ans 7 mois #9561 par sl1200mk2
Réponse de sl1200mk2 sur le sujet Device personality
Hi Edu,
congrats!!!!
you're the first ;-)
for the dimmer fine, this is not exactly how to do though...
There's a FINE attribut which you set to refer to the parameter you want.
In you case:
1st offset (attribut = INTENSITY), parameter = DIMMER
2nd offset (attribut = FINE), parameter = 1 (where 1 is the offset of the Intensity/Dimmer)
would you mind updating the personality, and after I'll publish it on the github
github.com/dlight-tools/dlight-devices
thanx,
il y a 11 ans 7 mois #9568 par Bestia Humana
Réponse de Bestia Humana sur le sujet Device personality
Hi Nico!
I did it this way at the begining but when I wanted to use it I was not able to find it to control it. It occurred to me to do it from EXTRA and it worked, I could control it .
It would be interesting in the future there could be a DIMMER or INTENSITY to control all of these issues.
It would also be interesting to change the values of different attributes using the keyboard. I was not able to do it. And as for the values of the attributes, we might choose to see them in DMX values (0-255) or percentage values. Especially for colors, because the values of the applications that I use to guide me are in percentage.
Thank you very much!!!!!
HASTA LUEGO!!!!!!
edu
WHEN THE MUSIC IS OVER
TURN OFF THE LIGHTS
il y a 11 ans 7 mois #9591 par sl1200mk2
If they're set, FINE are computed internally.
each parameters associated with a FINE can be controlled from the Device's attributes windows. except for the Dimmer...
so if you need to deal with this parameter, I've to figure out how to do...
nope, not for the moment.
in the future it will be possible from the Device's attributes windows.
of course.
will check that.
Temps de génération de la page : 0.151 secondes
