3.0.24
il y a 11 ans 8 mois #9425 par luiananda
Réponse de luiananda sur le sujet 3.0.24
I had a new problem, the day before I was running a show and it worked fine at the end I saved the show and closed the PC, the next day going to open the show, come a little window say error wrong color, set again, or a windows saying not find the file, which indeed the file where on the place where it was saved, I run the windows explorer and the show is where I saved, after many time restarting the System and the D::Light, I was able to open another file of the same show but I had in 15 Min. to reprogram everything, very stressful,with public just coming in, I have no idea why the show was not saved correctly, at the end of the show I saved again in two orders and reopened and it worked....I don't know what to say....also wrote in another comment, on the Patch file you can't anymore type a number on the channels or Dimmer to jump with the enter to Dimmer number you want, example, if I am on the Patch window and usualy if I was to dimmer 1 I could jump to a Dimmer 12, just marking the 1, put the 12 and enter, now if from 1 I want to go 18 I have to run all number one by one
Greetings, Luigi
il y a 11 ans 8 mois #9426 par sl1200mk2
Réponse de sl1200mk2 sur le sujet 3.0.24
Luigi,
sorry to hear that...
did you by chance kept the damaged .sho file?
if so, can you post it here?
nope, because it was leading to very bad things from certain users...
by the way you can use shortcuts to access either channel ('c' shortcut) and dimmers ('v' shortcut)
il y a 11 ans 7 mois #9540 par sl1200mk2
new beta 4.0.0_b26 is online
il y a 11 ans 1 mois #10717 par Wilf
Réponse de Wilf sur le sujet 3.0.24
I am running a new computer now, with OSX 10.10, the latest download of 3 is up to X.9. Can I use this safely for a show? Or is the Beta 4.0.47 safe enough...?
il y a 11 ans 1 mois #10718 par sl1200mk2
@Wilf,
there'll be no 3.0.24 for yosemite && >
and I believe 4.0.0_b47 is stable enough for standard (non Device) use.
I believe b47 is better regarding plenty of stuff and precisely regarding inhibition mechanism...
b48 wiil be better for Device and for chases as I'm adding TLinks && DLinks inside chasers.
Les utilisateur(s) suivant ont remercié: nomatter
il y a 11 ans 3 semaines #10833 par Benp
Réponse de Benp sur le sujet 3.0.24
Dlight 3.0.24 est-elle disponible pour linux 32b?
Ds la rubrique download je trouve uniquement la version 64b,
pourtant le 1er post de ce sujet précise que la version 3.0.24 sera compatible sous linux 32 et 64b...
Quelqu'un peut m'orienter?
il y a 11 ans 3 semaines #10834 par totoine
Réponse de totoine sur le sujet 3.0.24
désolé, la version 32bits a disparu dans une mise à jour du serveur. Et on ne l'a pas retrouvé dans le backup.
Mais aujourd'hui tu peux utiliser la 4.0b47 pour une utilisation avec des projecteurs traditionnels.
Il faut attendre confirmation de nico, mais elle a je pense la stabilité de la 3.0.24 pour la partie traditionnel.
il y a 11 ans 3 semaines #10835 par Benp
Ok merci de l'info je ne comprenais pas.
J'ai encore la 3.0.23 qui tourne sans problème, je vais continuer avec,
je voulais juste essayer la dernière version pour me tenir à jour.
il y a 11 ans 2 semaines #10876 par La Rotule
Réponse de La Rotule sur le sujet 3.0.24
Je cherche à télécharger, Dlight pour linux la version 32 bits. Seulement je ne la trouve nulle part. J'ai fini par voir cet article sur le forum, est-il possible d'obtenir un lien pour télécharger l'ancienne version?
il y a 11 ans 2 semaines #10877 par sl1200mk2
la 3.0.24 pour Linux 32bits s'est perdue dans la mise à jour du site.
j'ai pas le temps de la refaire, du coup il faut vous orienter vers la version en cours de dev à savoir à ce jour la 4.0.0_b47
il y a 11 ans 2 semaines #10878 par La Rotule
Ok dommage. Merci pour la réponse super rapide!
Mais du coup je ne comprends pas ce que c'est la "version en cours de dev à savoir à ce jour la 4.0.0_b47" c'est un autre logiciel?
il y a 11 ans 2 semaines - il y a 11 ans 2 semaines #10879 par totoine
Bonsoir,
la version en cours de développement est la prochaine version de D::Light qui sera la version 4.
Celle-ci est toujours en phase beta, ce qui veut dire que tout n'est pas stable. Elle apporte nottament la gestion des projecteurs asservis (devices). Cette section contient encore des bugs qui sont en cours de correction
Pour la partie 'traditionnel', elle peut-être considéré comme stable.
Tu peux trouver cette version dans la partie beta de la section téléchargement.
La 4.0.0_b47 signifie que c'est la 47e version beta (et oui déjà) de ce futur D::Light
il y a 10 ans 11 mois - il y a 10 ans 11 mois #11102 par dFVarela
Réponse de dFVarela sur le sujet 3.0.24
Hello, long time no see... I have the version 3.0.24 32 bits for Linux if you need it download it here !
dFVarela
Les utilisateur(s) suivant ont remercié: totoine, La Rotule
il y a 10 ans 11 mois #11105 par totoine
Thanks for this one.
I will upload it on the server !
il y a 10 ans 11 mois - il y a 10 ans 11 mois #11106 par dFVarela
I'm trying to download it and it looks like there is an error check first if everything is OK!
Can't dowload and open on Windows, can anyone download with Linux and try it? I can only do it later at home!
dFVarela
Dernière édition: il y a 10 ans 11 mois par dFVarela. Raison: Error on downloading whit windows!
Temps de génération de la page : 0.226 secondes
