- Remerciements reçus 1074
4.0.0_b6
il y a 12 ans 3 mois #8386
4.0.0_b6 a été créé par sl1200mk2
let's move on!
a new beta is available for macOS >= 10.8 and Windows (if you want the other builds, just ask.)
here's a non-finished list of modifications:
move CONTROL command
add HOME command
add Palette Macro function to set preferences for Palette recording
add Palette recording/updating functions
add Palette listing and editor
added +/-1 option for FOCUS commands
add the ability to use CTRL in the BLADE commands in order to scroll both Blade or Fine Balde
in the setup, add an option fro automagically switch to Device board at loading time
about Device Editor:
- rename it to Device Personnality Editor
- change internal display (need to rewrite personnality files... sorry)
- add a column to define if a parameter must be activate temporary (eg: Lamp On/Off needs to go to xx level then goback to 0)
attached a model of devices for the device editor.
I think it's robust now and you can build Personality based on the attached example.
if there's an english speaker that follow this beta stage, please correct grammar and sentence.
next step will be Cue and Group recording with Palettes
please give feedback about this work.
add HOME command
- xtineb
- Remerciements reçus 12
- xtineb
- xtineb
- xtineb
il y a 12 ans 3 mois #8398
par xtineb
Réponse de xtineb sur le sujet 4.0.0_b6
la pj veux pas passer.... alors copier/coller:
can not find channel named "stdout"
while executing
"puts "$col $row""
(procedure "editFixEditorTbleStartCmd" line 42)
invoked from within
"editFixEditorTbleStartCmd .fixtureEditor.f.sh.editor.tbl 5 4 0"
("uplevel" body line 1)
invoked from within
"uplevel #0 $data(-editstartcommand)
while executing
"puts "$col $row""
invoked from within
invoked from within
(procedure "doEditCell" line 148)
invoked from within
"doEditCell $win $row $col 0 "" $charPos"
(procedure "tablelist::condEditContainingCell" line 26)
invoked from within
"tablelist::condEditContainingCell $tablelist::W $tablelist::x $tablelist::y"
invoked from within
"if {[winfo exists .fixtureEditor.f.sh.editor.tbl.body]} {
foreach {tablelist::W tablelist::x tablelist::y} [tablelist::convEventFields .fixtureE..."
(command bound to event)
il y a 12 ans 3 mois #8399
Réponse de sl1200mk2 sur le sujet 4.0.0_b6
pour la pj:
mince.... c'est un truc de debug que j'ai oublié d'enlever...
pour le patch, sur le mac ça fonctionne, je vais essayer sur le PC et je te dis.
thanx
thanx
Les utilisateur(s) suivant ont remercié: xtineb
- xtineb
Temps de génération de la page : 0.167 secondes
