3.0.23
il y a 12 ans 6 mois #8092 par sl1200mk2
3.0.23 a été créé par sl1200mk2
I'm proud to announce the 3.0.23 release of D::Light.
It's available for each supported platforms (macOS 10.6->10.9, windows, Linux 32b, Linux 64b).
On MacOSX, it's linked against XQuartz 2.7.5 (xquartz.macosforge.org/landing/)
This one should fix ultraDMX RDM Pro widget recognition
'Colour Panel' is modeled after the 4.x beta process
please report any suggestions/wrong behavior
Nicolas
il y a 12 ans 5 mois - il y a 12 ans 5 mois #8176 par rodolpheletourmy
Réponse de rodolpheletourmy sur le sujet 3.0.23
After two weeks of intense live use, I have to report NO CRASH AT ALL (ZERO) with this one. Good job Nico !
I run it on Linux32, Ubuntu 12 LTS - I should mention it as it seems to be pretty important detail.
All windows users who plans to use D-Light in a profesionnal (or "serious") setting, without having to worry about some random stability isues, should really consider the Linux version as THE solution.
For my personnal experience, when I changed to Linux 2 years ago, 95 % of the strange "problems" I experienced before (while using a very stable and clean windows XP), were just fixed, and for good !
In most theaters, local tech. crews are quite impressed when they see D-light running (...the last iphone remote layer whith patching functions is incedible ^^)... this is particulary true for the few of them were, at first, the most "skepticals" about using it (considering computers like very "unsafe" in general... they may dunno that any professional desk today is nothing more than a computer, itself :-) )
Regards to all / Bien à vous tous !
Rod
Dernière édition: il y a 12 ans 5 mois par rodolpheletourmy. Raison: petites fautes par-ci par là
il y a 12 ans 5 mois #8199 par sl1200mk2
Réponse de sl1200mk2 sur le sujet 3.0.23
thanx Rodolphe!
combo DL + phone remote is a killer B)
il y a 12 ans 4 mois #8219 par xavier12
Réponse de xavier12 sur le sujet 3.0.23
Bonjour
J'utilise Dlight sur un mac 10.7.5 et avec un boitier enttec Open Dmx Ethernet
Jusqu'à maintenant j'utilisais la version 3.0.10 sans aucun soucis.
J'ai voulu faire la mise à jour vers la dernière version 3.0.23 et quand j'ouvre un show les projos se mettent à clignoter ! :S
Est-ce que quelqu'un a une explication ?
J'ai fait un export ascii avec la 3.0.10 et je l'ai importé dans la 3.0.23 ça a l'air de fonctionner mais je préfère demander au cas où car je ne suis pas très serein.
Xavier
Xavier
il y a 12 ans 4 mois #8223 par sl1200mk2
ya eu des boulversements depuis la 3.0.10....
après l'import ascii et réenregistrement de ta conduite et réouveture du nouveau sho, est-xce que t'as toujours des soucis?
il y a 12 ans 4 mois #8228 par xavier12
Apparemment tout fonctionne comme il faut : super !
Xavier
il y a 12 ans 4 mois #8252 par fIfOU
Réponse de fIfOU sur le sujet 3.0.23
Petit rappel d'un problème de démarrage lent depuis la 3.0.22 (ou avant, mais la 3.0.18 démarre normalement)
Problème présent sous OSX 10.6.8 (et sous 10.8), testé avec tous les XQuartz (2.7.3, 2.7.4, 2.7.5, 2.7.6)
Bon courage à toi Nico
Philippe
il y a 12 ans 4 mois #8262 par lordbao
Réponse de lordbao sur le sujet 3.0.23
sl1200mk2 écrit: hello,
J'ai les même problèmes que Xavier, en passant de la version 2.5 à la 3.0.17. Ce problème de clignotement (ou effet feu de bois) persiste également avec la 3.0.23, pendant les mémoires. Il n'est pas systématique mais récurrent.
Que faire ? Je ne comprend pas bien l'import ASCII, etc... Une brève explication ?
Merci !!!
Bao
il y a 12 ans 4 mois #8263 par lordbao
je précise que j'utilise DL avec QLab 2.3.9 sur Mac OS 10.6.8 avec un boitier ENTTEC Pro DMX MK2. Mon problème ne vient ni des gradateurs, ni d'installation électrique de la salle.
il y a 12 ans 4 mois #8264 par xavier12
Pour résoudre le problème tu ouvres ton .sho avec la version 2.5
Tu exportes en ASCII, penses aussi à exporter le patch midi, tes fx, ton patch
Tu ouvres la version 3.0.23 et tu importes l'ASCII, et tout le reste.
Ça devrait fonctionner... enfin j'espère car la 2.5 est vraiment vieille.
Xavier
il y a 12 ans 4 mois #8265 par lordbao
Merci beaucoup pour ta réponse si rapide.
Quand je veux exporter en ASCII, DL me propose d'écrire sur un ficher DS.store déjà existant. Est-ce la bonne manip ? Aussi, DL ne me laisse pas exporter dans un dossier spécifique, par exemple sur le bureau, où je voudrais. Qu'est-ce ASCII ? Un certain format de fichier pour ma conduite ?
(Aussi, cela n'a rien à voir je pense, mais la version 2.5 ne supportait pas encore les fichiers .sho. Ma conduite se trouve sous la forme d'un dossier qui comprend une multitude d'autre sous-dossier (BIN, Patch, Sequence, etc...) )
il y a 12 ans 4 mois #8267 par lordbao
Re-bonjour,
J'ai pu exporter ma conduite en .ASC
Cependant après import du fichier ASCII, X11 m'indique "done" puis Dlight 3.0.23 se ferme (crash?). Une idée de ce qui se produit ? Est-ce normal ?
il y a 12 ans 4 mois #8271 par sl1200mk2
est-ce que tu peux poster un .zip de ton ascii pour voir?
il y a 12 ans 2 mois #8479 par lordbao
Pardon pour le retard, voici mon fichier ASC.
La pièce jointe Bao.ASC.zip est absente ou indisponible
il y a 12 ans 2 mois #8480 par fIfOU
Hello, j'ai essayé d'importer ta conduite avec la 3.0.24b2.
ça a l'air correct.
Peut-être qu'il faut faire, "new show" avant d'importer..
Voici le résultat de mon import en .SHO
Philippe
Temps de génération de la page : 0.215 secondes
