3.0.19_b3
il y a 12 ans 10 mois #7372 par sl1200mk2
3.0.19_b3 a été créé par sl1200mk2
bug fix.
thanx for your tests.
il y a 12 ans 10 mois #7375 par vbs
Réponse de vbs sur le sujet 3.0.19_b3
Hi
I see that the Inhabitation display is not there any more?
In the version 3.18 it was still there but he when you set a channel in inhabitation it was not visible in the display.
Regards Vincent
il y a 12 ans 10 mois - il y a 12 ans 10 mois #7376 par colinc
Réponse de colinc sur le sujet 3.0.19_b3
@Vincent
The way inhibition works has changed, so the old inhibition window has gone. Now, you select some channels you want to inhibit, create a group with them, and then attach that group to a submaster. In the FLASH/TIME selector for the sub, you will now see a third option - INHIBIT. If you make that submaster an IHIBIT submaster, then wnen it is at FULL, any live channels in eg, the sequence window, which are part of the INHIB group will have their output proportionately reduced. See the thread on Inhibition in the 'Main' forum.
Regards,
il y a 12 ans 10 mois #7377 par vbs
Hi Collin,
Great This is a fine improvement!!!!!!!
Thanks
Regards Vincent
il y a 12 ans 10 mois #7383 par sl1200mk2
Réponse de sl1200mk2 sur le sujet 3.0.19_b3
Hi,
does anyone have problems installing this beta on a windows 8.1 computer?
thanx,
il y a 12 ans 10 mois #7394 par vbs
Today i notice that if you have the desk in @Mode and you want to record a cue it don't record it.
For instance que - 4.1 - rec - enter Noting is happening
In RPN mode it works and you see it is recorded
Regards Vincent
il y a 12 ans 10 mois #7395 par sl1200mk2
in @Mode, the sentence is [REC] 4.1 [ENTER]
il y a 12 ans 10 mois #7396 par sl1200mk2
does anyone have a friend with win8.1 to test installation of the latest beta?
il y a 12 ans 10 mois #7398 par vbs
is this a little confusing in the @mode
To update the cue i can use 4.1 [update] [enter]
If i want to rec a que the i aspect to start with the [cue] or 4.1 than [rec]
il y a 12 ans 10 mois #7399 par sl1200mk2
:huh:
what is [UPDATE]?
when I try to modify:
[MODIFY] x [ENTER] -> modify the cue x
[REC] x [ENTER] -> record the cue x
[MODIFY] [ENTER] -> modify the cue in the activ' register
x [MODIFY] [ENTER] -> modify the cue in the activ' register
don't you have the same behavior?
Temps de génération de la page : 0.156 secondes
