3.0.16_b3
il y a 13 ans 4 mois #6563 par sl1200mk2
3.0.16_b3 a été créé par sl1200mk2
bug fix.
OSC library has been updated.
more OSC stuff for remote patching.
here's a summary of all the commands (you need to add /patch/ in front of all of them):
Code:
struct oscPatch { char *key; int len; } oscPatch_st[] = { { "channel", 7}, //0 set the active channel of the patch { "next", 4}, //1 simulate DOWN key { "prev", 4}, //2 simulate UP key { "dimmer", 6}, //3 set the active Dimmer of the patch { "switch", 6}, //4 switch between Channel/Dimmer or Dimmer/Channel config { "displayLevel", 5}, //5 display pour Level { "thru", 4}, //6 set the thru dimmer box { "plus", 4}, //7 add function { "moins", 5}, //8 remove function { "launch", 6}, //9 launch/kill patch window { "1", 1}, //10 { "2", 1}, { "3", 1}, { "4", 1}, { "5", 1}, { "6", 1}, { "7", 1}, { "8", 1}, { "9", 1}, { "0", 1}, { "dot", 3}, //20 { "displayChannel", 14}, //21 display pour Channel { "displayDimmer", 13}, //22 display pour Dimmer { "displayThru", 11}, //23 display pour Dimmer { "input", 5}, //24 zone de saisie { "levelRequest", 12}, //25 ask 4 change test level { "clear", 5}, //26 clear input { "testDimmer", 10}, //27 test function 4 Dimmer { "testChannel", 11}, //28 test function 4 Channel { "displayActiveChannel", 20}, //29 display active Channel { "displayActiveDimmer", 19}, //30 display active Dimmer { "displayActiveThru", 17}, //31 display active Dimmer Thru { "enter", 5}, //32 enter };
happy testing,
if everything is fine, I'll publish it as a release next week.
