- Remerciements reçus 1074
3.0.15_b7
il y a 13 ans 6 mois #6301
Réponse de sl1200mk2 sur le sujet 3.0.15_b7
@Colin,
can you try something risky
on the libusbx list, they would like to know if the latest libusbK driver is working well, so can you try to install it via zadig.exe and try to open the ultraDMX (with the latest DL beta code).
thanx in advance
thanx in advance
- colinc
- Remerciements reçus 22
il y a 13 ans 6 mois - il y a 13 ans 6 mois #6302
par colinc
Réponse de colinc sur le sujet 3.0.15_b7
Hi Nico,
Well, waddya know...(another Bingo!...)
Yes, the libusbK driver 3.0.5.16 that comes with Zadig once installed for the DMX Micro,connects and disconnects ok with DLight 3.0.15_b8. No lighting to actually test on at the moment, but the DMXMicro's little LED flickers away at the 'Connected' rate just fine...
*And* - if I reinstall the WinUSB driver after trying out the libusbK driver it connects again too!!
Double bingo!!
:woohoo:
Double bingo!!
:woohoo:
il y a 13 ans 6 mois #6303
@Colin,
thanks for the tests.
so I think that you should remove the libusbK driver in order to use the WINUSB one.
from what I understand of the answer on the libusbx lists, DL will use lisbusbK driver if it's present. if it's not it'll use WINUSB.*And* - if I reinstall the WinUSB driver after trying out the libusbK driver it connects again too!!
- colinc
il y a 13 ans 6 mois #6304
par colinc
Hi Nico,
What I meant was, that if I rerun zadig after using llibusbk, and re-install WinUSB, then DLight also connects with that - whether it is through libusbK.dll or libusb-1.0.dll I don't know, but in both cases, it just works now -without having to remove anything.
Regards,
Regards,
il y a 13 ans 6 mois #6306
I've asked the list what's the difference between both.... will see.
at least, it's a good news that we can use both drivers and maybe the difference is that I can distribute libusbK.dll and avoid the zadig steps...
I think it's through libubsK drivers.whether it is through libusbK.dll or libusb-1.0.dll I don't know
Temps de génération de la page : 0.138 secondes
