3.0.12_b8
il y a 13 ans 7 mois #5777 par sl1200mk2
3.0.12_b8 a été créé par sl1200mk2
go ahead!!
new piece with new shit:
OSC:
you're now able to use several IP as output. (be carrefull, there's ni IP conformity check).
so please test:
-wrong IP,
-same port as the reader
-several writers (of course)
-creation/destruction of writers
MIDI:
int the setup you're now able to select between several Input/Output.
I also rewrite all Midi assignation and bring in output for channels ( :ohmy: )
if you record several CC for a function (except for Xfade), they now behave correctly.
in the Midi editor (that now belongs to 'Display' menu, there's a new 'script' button that fill basic records.
so please test:
- several input/output
- midi output for channels
-same functions across Midiswitch
General:
DMX Universe / Channels Universe have been cleaned... here comes 'ROOMs' for channel.
that mean that 1 Room = 512 channels, 2 Room = 1024 channels, etc...
from Room 1 you can cross patch to DMX universe, etc...
so please test in the Patch Editor:
-Clean 1:0/1:1 for a single DMX universe, for another, for All
-assignation of dimmer from universe x,y,z to a channel of Room 1, or 2, etc
Time:
you can now set 0.01 as time for xfade, wait, etc...
so please test in Main Seq, FX, etc...
DMX:
OLA had bee updated to 0.8.27 but there's something wrong with usb and OLA
I didn't fix yet BlackOut stuff, and levels of Master that are incorrect when you launch DL.
thanx for your reports,
Nico
il y a 13 ans 7 mois #5780 par sl1200mk2
Réponse de sl1200mk2 sur le sujet 3.0.12_b8
21h30:
I've just pushed an update (without changing the tag of the version _ for win32 && OSX) as a friend reported that accessing Midi device lead to crash.
so I've fixed it.
you can now test safely.
il y a 13 ans 7 mois #5786 par sl1200mk2
c'est une des première fois qu'il n'y a pas de retour sur une beta...
soit c'est bon signe soit il y a une désaffection majeure pour le soft B)
en tout cas, more to come avec la b9 qui apportera son lot de corrections suite à la session de formation à Lyon
il y a 13 ans 7 mois #5787 par xtineb
Réponse de xtineb sur le sujet 3.0.12_b8
Alors,je me lance pour une "réponse"...
deux applis ouvertes: Dlight 3.0.12_b8 et Ableton Live.
Très peu d'effets (sur les deux)
Le problème n'est pas instantané mais au bout de quelques temps:
La charge du processeur passe à 100% et y reste même si on arrête toute manipulation.
Donc: impossible de quitter l'application, éteindre, mettre en veille l'ordi...
Même soucis avec 3.0.12_b7
A priori pas de problème avec 3.0.10
Essais effectués sans gradateurs.
win xp 32 Intel Pentium 2.13GHz 2G RAM / Nanokrontrol / Boitier USB PRO Enttec
Je sais pas si çà fera avancer le schlimi.....chimili.......smili....chimilili
christine
il y a 13 ans 7 mois #5789 par sl1200mk2
hello Xtine,
comment communique les deux soft? en OSC ou Midi?
d'ailleurs, est-ce que les deux soft communiquent?
est-ce que t'as moyen de voir quel soft fait monter le CPU à fond?
Nico
il y a 13 ans 7 mois - il y a 13 ans 7 mois #5790 par xtineb
sl1200mk2 écrit: comment communique les deux soft? en OSC ou Midi?
j'ai juste affecté (en MIDI) une partie du nanoKontrol à Dlight et l'autre à Live
sl1200mk2 écrit: est-ce que t'as moyen de voir quel soft fait monter le CPU à fond?
par le gestionnaire de tache de windows, je vois que c'est Dlight :(
il y a 13 ans 7 mois #5791 par sl1200mk2
t'as pas une boucle Midi genre DL qui envoi des infos sur le midiOut vers Live qui renvoi des infos vers le midiIn de DL, etc...
il y a 13 ans 7 mois #5792 par xtineb
Bingo !
Bien sûr c'était sûrement çà !
Pour mon utilisation où c'est le NanoKontrol qui "pilote" les 2:
J'ai donc DLIGHT: MIDI IN : NanoKorg . MIDI OUT: none
et Live: ENTREE: NanoKontrol + TELECOMMANDE ACTIVEE. SORTIE: none
et çà fonctionne :) :)
Je passais par MIDI Yoke Je voulais que live "commande" dlight mais... j'ai besoin d'un cours !!!!
En tout cas GRAND MERCI, comme toujours t'as la solution et je salue encore une fois ta réactivité.
Quelle chance nous avons
christine
il y a 13 ans 7 mois - il y a 13 ans 7 mois #5797 par colinc
Réponse de colinc sur le sujet 3.0.12_b8
Salut Nico
3.0.12_b8 - Windows Vista HP
A lot of crashes when closing the program - particularly after making a change, eg to MIDI ins/outs, or DMX, eg turning off USB or changing to ArtNet. No pattern - but tell me where DLight puts its Error reports and I'll attach them
Regards
il y a 13 ans 7 mois #5798 par sl1200mk2
@Colin,
I'm afraid there's no readable crash report on windows (at least none I can read...)
I've to track down these issue one by one.
so for example:
when you switch on/off midi, it crash on exiting?
when you add midi inputs, it crash on exiting?
when you add midi outputs, it crash on exiting?
etc...
I think they're all related as internal structure management are almost the same.
il y a 13 ans 7 mois #5800 par xtineb
pt'it crash quand 2nd clic sur "la feuille" blanche du setup MIDI
xtine
il y a 13 ans 7 mois #5801 par sl1200mk2
Hello Xtine,
bien vue pour ce bug, merci!
j'ai appelé cette feuille blanche 'Script' ;-)
il y a 13 ans 7 mois #5802 par sl1200mk2
@Xtine,
fixed pour la prochaine béta :)
Les utilisateur(s) suivant ont remercié: xtineb
il y a 13 ans 7 mois #5813 par sl1200mk2
@Colin,
I cannot reproduce mentioned bugs...
maybe it's because I've ever change stuff...
there are other change for the b9, so I think I'll publish it soon...
@Xtine,
est-ce que t'as constatée des crashs à la fermeture du soft après avoir fait plusieurs/différentes affectations In et Out du Midi?
il y a 13 ans 7 mois #5814 par xtineb
Nico,
A priori je n'utilise que le in midi (puisque nanokrontrol) :
je change des affectations de sub, flash, ect... sur le setup midi, et là j'ai pas de problème.
je peux quitter dlight normalement.
Mais peut être tu parle pas de çà mais d'affectation d'autres soft ou machines MIDI?
Désolée, ne sais pas, car je pense que j'ai encore pas compris comment çà fonctionne :blush: :blush:
merci pour le SCRIPT mais encore la "tielle" de service, je comprends pas à quoi çà sert!
bises
Temps de génération de la page : 0.224 secondes
