Confused about Palette and leds behavior
- NachoL
Some more video-tutorials would be very nice, the ones in the web page are very old
Thank You
- LightUP69210
- Remerciements reçus 1
If i have understood the problem:
Have you recorded the palettes with "same personality devices" mode selected?
If not, you must edit each palette to ad the ch if the new devices.
in your case you would want to clone devices (in the deviceListing) in order to automatically add new ones to palettes and eventually to DLinks and Presets.
- kreps
- Remerciements reçus 11
English is not my forte, but i'll try to help.
Lightup is right, but you could also clone the devices instead of creating new ones and select clones source devices in palettes and clone source devices in cues and cuelink.
- kreps
- NachoL
Thanx
- NachoL
- NachoL
for exemple your create a Preset for the backLights registered with some levels, and if you don’t block Preset référence, levels of the cue will be levels of the Preset. It’s very handy for Touring because if you modify the Preset every cues that référ to it will be updated.
but it can be a sort of gymnastic that is not easy for everyone… so Preset référence is blocked (not use) by default.
hope this helps
- kreps
File Edit ... Licence Help
you need the last versio of dlight
