Opening old files
- joancotros
il y a 5 mois 3 semaines #30384
par joancotros
Opening old files a été créé par joancotros
Hi,
I'm trying to open some files from an older version on the newly download version of
:light and they are not opening, neither as .sho or ascii. Any ideas of what can I do?
Thanks a lot,
Joan
:light and they are not opening, neither as .sho or ascii. Any ideas of what can I do?Thanks a lot,
Joan
il y a 5 mois 3 semaines #30385
Réponse de sl1200mk2 sur le sujet Opening old files
Hi Joan,
you can not do that...
you can open old files with new DL but not new files with old DL
- joancotros
il y a 5 mois 3 semaines #30386
par joancotros
Réponse de joancotros sur le sujet Opening old files
Hi, thanks for the quick reply!
I've been trying to export as ascii and delete some parts of the file to detect what was causing the problem. Essentially everything works except the chasers. Erasing that part I managed to recover the cues and submasters.
Then I added some chasers on the new version and exported as ascii, to understand what was the format that could be causing the problem. I discovered that the problem is with the importint chasers with ascii, as the software can't even open the file that just printed minutes ago. So it's not about the format i think, it is probably just a bug or something that prevents from importing the chasers information.
If any ideas come up, I'll be more than happy to listen.... there's lots of chasers in my show and if not, i'll need to add them one by one.
Thanks!
Joan
Thanks!
Joan
il y a 5 mois 3 semaines #30387
if you think that there's a bug please come on Discord as it's easier to discuss
(please note that WeekEnd is there... and I'll be unavailable for 3 days at the beginning of next week)
- joancotros
il y a 5 mois 3 semaines #30402
par joancotros
hi,
How do i join? Do i need an invite?
- kreps
- Remerciements reçus 11
il y a 5 mois 3 semaines #30404
par kreps
Réponse de kreps sur le sujet Opening old files
Hello, the link is on the home page
Temps de génération de la page : 0.138 secondes
