Making a Fixture for Macwash 1915Z 3 groups of colors
- NachoL
il y a 1 an 8 mois #28263
par NachoL
Making a Fixture for Macwash 1915Z 3 groups of colors a été créé par NachoL
The DMX table for this Wash in 23 channel mode says
CH9 Red first group ....CH13 Red 2nd group ....CH17 Red Third group I guess to make the fixture I just have to put color etc in every Channel but could someone explain me what are this groups for? I I have to program colors do I have to Dimm every group?
thank you
thank you
il y a 1 an 8 mois #28266
Réponse de sl1200mk2 sur le sujet Making a Fixture for Macwash 1915Z 3 groups of colors
in case of multicell devices there's generally several Dimmer.
Dimmer 1 will control first of red/green/blue, dimmer 2 will control second block of red/green/blue etc...
so you'll say
offset a - dimmer - group 1
offset b - red - group 1
offset c - green - group 1
offset d - blue - group 1
offset e - dimmer - group 2
offset f - red - group 2
offset g - green - group 2
offset h - blue - group 2
you can have a look at Martin/MacAura for an example
so you'll say
il y a 1 an 8 mois #28267
well... I've found the Macwash 1915Z manual and there's no several dimmers.... just zones
here's a personality (but RESET offset is a bit flacky...)
- NachoL
il y a 1 an 8 mois #28269
par NachoL
Réponse de NachoL sur le sujet Making a Fixture for Macwash 1915Z 3 groups of colors
Yes, I was going to share you the DMX Table. I guess The channels of the groups just work as virtual dimmer. What means flacky about the reset? can you tell me What can Happen and what can I try?
Thanx a lot!
Thanx a lot!
il y a 1 an 8 mois #28271
Flaky means that they don't give much informations....
And please be sure that your DL is up to date.
- NachoL
il y a 1 an 8 mois #28274
par NachoL
Thanx, yes, I'm in DL 4.5.16
Temps de génération de la page : 0.131 secondes
