Selected directory is not writable
- polillin
is it a macOS or a PC?
also which version of DLight do you use?
- polillin
I use the last
:light 4.3.23, but it happened the same with the previous one Connexion pour participer à la conversation.
so you need to clean stuff a little bit...
-Close your DLight
-Open a file explorer
-navigate to C:
-in the upper side of the explorer, Select View > Show > Hidden items.
(you should see ProgramData folder)
-navigate to ProgramData/DLight folder
-send to trash everything that end or start with 'tmp'
-restart your DLight and try a save as.
tell me how it goes.
- polillin
- polillin
- polillin
- polillin
One observation: I have a different folder to keep my .sho files. And if I rightclick on it, it says it is a only read folder, don't know if it has anything to do with it...
- polillin
