X-Fader behavior
il y a 3 ans 4 mois #25367 par stebian
X-Fader behavior a été créé par stebian
I'm using X-Faders via OSC to move between cues.
When halfway moving into a new cue and then back, it doesn't matter which other cue I load into prep register, I always have to fade through the cue I like to skip.
That doesn't apply for the use of GO and GOBACK buttons.
stephan
il y a 3 ans 4 mois #25371 par sl1200mk2
Réponse de sl1200mk2 sur le sujet X-Fader behavior
hi,
my English is not as accurate to exactly understand what you mean....
can you post a video or something and tell me what's the wrong behaviour you observe
il y a 3 ans 4 mois - il y a 3 ans 4 mois #25374 par stebian
Réponse de stebian sur le sujet X-Fader behavior
Ok, I hope my video will help
What happens is that if I fade halfway into the new cue and then back, that new cue gets locked into the prep register. I can load any ather cue into prep but it will fade into the "locked" cue first.
stephan
il y a 3 ans 4 mois #25379 par sl1200mk2
Hi,
it's clear... thanks you for the video.
for now I have to find a way to replicate it in OSC.... which version of D::Light do you use?
il y a 3 ans 4 mois #25380 par stebian
That's been on 4.3.19.
stephan
il y a 3 ans 4 mois #25383 par sl1200mk2
ok, I think I got it fixed.
would you mind testing a preview? which system are you running?
il y a 3 ans 4 mois #25384 par stebian
Brilliant! I'm on win10 64bit
stephan
il y a 3 ans 4 mois #25385 par sl1200mk2
ok,
I'll send you a weTransfer when it's baked
il y a 3 ans 4 mois #25386 par sl1200mk2
so...
I've uploaded DL4.3.21_b1 in the download/beta section of the website.
thank you for your feedback
il y a 3 ans 4 mois #25389 par stebian
Works now. Thank you Nicolas!
stephan
il y a 3 ans 4 mois #25391 par sl1200mk2
perfect, thank you for your feedback.
may I ask you what's is your hardware? it's not that common to find hardware that exports OSC command...
il y a 3 ans 4 mois #25392 par stebian
It's a controller I build for the use with D::Light. I wanted a lightwight lighting desk which I can take on the airplane if I do a show somewhere far away. So it consists of two OSC controllers actually that i can fold into one little wooden case. One is just a faderbank of 48 faders and the other one has 24 fader plus buttons to control D::Light plus master faders and X-faders.
Both controllers are based on the Teensy 3.6 microcontroller.
But we chatted about that 3 years or so ago.
stephan
il y a 3 ans 4 mois #25393 par sl1200mk2
wow man!!!
I think you've built what a looooot of people want!!
I remember our chatting , but I forgot (so shamed....)...
did the wheel also works?
the Width x Height of the box looks very nice, the design too !!
it's handMade but can it be serialMade?
il y a 3 ans 4 mois #25395 par stebian
Thank you!
The wheel works as well.
I'm sure it can be manufactured in series. That would involve a lot of work of course. Not sure how to do that.
stephan
il y a 3 ans 4 mois #25396 par sl1200mk2
I don't know neither... I guess it would be an half time job... are you willing digging into this?
from my point of view, doing hardware involve a lot of CEE certifications and boring things that I don't wish to anyone.
sharing code and PCB stuff (along with screwing diagram  ) could be something but that's up to you.
Temps de génération de la page : 0.192 secondes
