External numpad keyboard
- Xtec81
:light (I'm sendig a picture and screenshot to show you what I'm talking about)... Also comen that "Esc" aren't recognizet too in this last version (I've been using a friends computer with V 4.0.0_72) and there "Esc" was assigned as "Kill all subs" by default... Do you know if there are any solution about? Thank you!
Xavi Calvet
- Xtec81
when "=" 060
Xavi Calvet
did you try with DL4.3.12?
- Xtec81
Those buttons are recogniced as a text, but not as a shortcut; "Esc" aren't recognizet, too (but I'm supousing that ther are a reason about) ... I'm sanding a picture too
Salut!
Xavi Calvet
that's clear, encoding is failing in the shortcut editor !!
i'll fix that for the next release.
thanks,
I've tried to plug the raspbverryPi keyboard on my PC but it delivers '(' for '('
so I have nothing that match your external keypad (in order to fix it
- Xtec81
Xavi Calvet
but you confirm that when you want to Enter text in the main window, characters are ok?
it's only in the shortcutEditor that it's a mess?
- Xtec81
Is as a shortcut When those caracters are unrecognizet... I tryed on a notepad , Word and txt editor and it "works fine"
Xavi Calvet
can you send me your email (via the Contact tab of the website)? I would like to send you a beta test if possible (on windows that's right?)?
thanks,
