unable to activate licence
- videopata
Again.
I’m running version 4.3.04 with XQuartz 2.8.1 on OS 10.10.5.
All the sugestions/solutions for the apple bug are not fixing the problem with the activation of the license.
Please help.
Thanks
All the best
let's restart...
-first install the latest XQuartz (2.8.2) then reboot your computer (don't forget to reboot, it matters a lot...)
-install DL 4.3.10 (or 4.3.11 as I think I'll publish it today)
-download the appleBug.command program that you can find here:
getdlight.com/media/kunena/attachments/42/appleBug.command.zip
-unzip appleBug.command and launch it (it should open a Terminal).
-this program should download 2x .pem files which are security certificate, and prompt for your password.
before typing your password, be sure that certificate's download have succeded (you should read some numbers different of 0).
then type your password and validate with Enter.
at this point launch DL, go to Licence menu then do Deactivate, (DL should run in DEMO mode), go to Licence menu then do Activate.
tell me where it fails.
- videopata
Thanks for your patience.
Ok I've downloaded DL version 4.3.11 and XQuartz 2.8.2 and run the applebug.command.
I think the .pem files didn't download:
Last login: Wed Sep 28 08:28:32 on ttys000
videopatas:~ videopata$ /Applications/appleBug\ 2.command ; exit;
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0curl: (35) SSL peer handshake failed, the server most likely requires a client certificate to connect
Password:
I've already the isrg-root-x2.pem and isrgrootx1.pem in the system keychain, when in last attempts I transfered them to the root and add them via terminal. The ISGR Root X1 and ISGR Root X2 certificates are in the system keychain and have custom trust settings and are with always trust option.
I've launched DL and the problem persists (
:Light is deactivated on this computer wil run in demo mode; Deactivate previous license first).Connexion pour participer à la conversation.
unzip them and place them in the HOME directory (/Users/Videopata)
then launch again the appleBug.command, it will fail to download the .pem files but you don't care (as you already got them)
run DL and do Deactivate then Activate
(please be sure that Firewall (in preferencesSystem/Security) is OFF)
- videopata
Did all you said and terminal text is:
Last login: Wed Sep 28 16:34:25 on ttys000
videopatas:~ videopata$ /Users/videopata/Applications/appleBug.command ; exit;
0 0 0 0 0 0 0 0 --:--:-- 0:00:01 --:--:-- 0curl: (35) SSL peer handshake failed, the server most likely requires a client certificate to connect
Password:
logout
[Process completed]
Launched DL, deactivate and activate, and same result: Deactivate previous license first.
Firewall has been always off.
- videopata
should i try the new release?
:Light.I think we're done with this computer...
I can send your money back for your licence if you want. I'm really sorry we didn't succeded with your computer.
you could also try to update your macOS to a more recent unsupported version:
dosdude1.com/catalina/
- videopata
the fact that i don't upgrade to a new OSx it's because i use software that doesn't have upgrades for newer OSx.
Not Catalina! but today i tried El Capitan, launched DL, deactivated and activated the license and...
Hurrah!!!
Now i'm running OS X 10.11.6 with DL 4.3.11 and Xquartz 2.8.2.
So many thanks for your help and for all your patience and time!
All best
P.S.: is it possible that this will happen again? if so, how can i prevent it?
Hi,
you should run the 4.3.12 which fixes a little mistake about Fine parameters (mea culpa...).
the only way to exactly prevent it is to upgrade the macOS.P.S.: is it possible that this will happen again? if so, how can i prevent it?
Now, as your computer is able to process crypted communication it should be fine for a while.
- videopata
thanks
