DYNAMIC BOTTOM
il y a 5 ans 1 mois #22119 par polillin
DYNAMIC BOTTOM a été créé par polillin
Is there a BUTTON hidden somewhere in the screen for this function or is it just the name of the interchangeable Devices / Submasters option?
So, I can only set it through Menu / Devices / Dynamic Bottom or through the shortcut (not very short) Shift + Control + d ?
il y a 5 ans 1 mois #22120 par polillin
Réponse de polillin sur le sujet DYNAMIC BOTTOM
It would be really useful to have a MIDI button assigned for this option, although I suspect there is no such MIDI option...
il y a 5 ans 1 mois #22121 par sl1200mk2
Réponse de sl1200mk2 sur le sujet DYNAMIC BOTTOM
HI,
you can automate dynamicBottom toggling in the setup if you select 'dynamic selection for Channel' option.
Thus each time you select a device it will switch state. (use ESC to revert to submaster)
There is also Shift+Tab unknown shortcut to toggle dynamicBottom State
Les utilisateur(s) suivant ont remercié: polillin
Temps de génération de la page : 0.125 secondes
