INHIBIT FUNCTION IN A SUBMASTER
- polillin
il y a 5 ans 1 mois #22092
par polillin
INHIBIT FUNCTION IN A SUBMASTER a été créé par polillin
I'd like to program a submaster to inhibit, lets say, the frontal light so in case it is too much intensity I can take out some live or in the process of readapting a show to a particular stage.
I put 'inhibit' in a submaster with all my frontal channels at full and click inhibit, but I can't get it working. I also tried with target in "00" but no result. Where am I wrong? Thanks!
- en ligne
il y a 5 ans 1 mois #22093
Réponse de sl1200mk2 sur le sujet INHIBIT FUNCTION IN A SUBMASTER
Hi,
you have to open the submaster in order to inhib.
the more you'll open it, the more it'll inhib channels inside.
tell me if it's ok.
tell me if it's ok.
Les utilisateur(s) suivant ont remercié: polillin
- polillin
il y a 5 ans 1 mois #22101
par polillin
Réponse de polillin sur le sujet INHIBIT FUNCTION IN A SUBMASTER
I do open the submaster and it only marks a square around the channels's level in the circuits screen, but it doesn't reduce the intensities.
- polillin
il y a 5 ans 1 mois #22102
par polillin
OK. I will answer myself. I found the solution in this old post
getdlight.com/forum/2-releases/5372-3-0-24-b2#8295
I was working blind, today I connected a PARLED and could verify that DLight does apply the inhibition and marks with a square the channels it inhibits BUT it does not reflect the actual intensities in the sequentiel, right? Even when the light is at 0%, the screen marks your channel at FULL (in my case) with a square around it.
- en ligne
il y a 5 ans 1 mois #22103
that's it !
inhib does not modify displayed levels, it only applies on DMX output.
the reason is that sometimes you can inhib/scale some levels just for a moment but when you record/update a cue you probably want to record initial levels, not the scaled ones.
Temps de génération de la page : 0.124 secondes
