VLC avec D-Light
- siger
Quelqu'un peut-il m'aider à comprendre ??
Merci d'avance
Régis
- en ligne
sur macOS ? PC ? Linux ?
sur PC faut p-e mettre une règle dans ton firewall...
- polillin
Everything supposedly allright and red light OFF.
I remember that:
1) I ensured myself to record the interfaz advanced preferences in VLC, close and open everything again.
2) I updated some pendant W10 options and restarted the PC. Suddenly it gave me green light.
(MAYBE OFFTOPIC, BUT RELATED...)
3) I installed the Korg Nanokontrol2 driver and D:light didn't recognize my USB-dmx EnttecPro (Red light again) but it worked when I reinstalled the enttec driver again
4) in MIDI, I had to look for a way to open the MIDI port with MIDI Tools.
5) today, I sent DMX to stage from Dlight and it didn't work, except for 2 lamps, hahahahahahaha, I had copied with another patch different than 1:1. Finally I noticed!
6) By the way, I use VLC to trigger a VLC list of music tracks with Slinks, but I have desisted of the Mlinks for volume control, I can't get it running perfectly, it kept giving me surprises on airshow, like keeping at zero and not fading in until FF...
- en ligne
Hi,
Windows can be in an unstable state when there's some pendant updates and it requires you to restart.I updated some pendant W10 options and restarted the PC. Suddenly it gave me green light.
I don't think it's related to your VLC issue.3) I installed the Korg Nanokontrol2 driver and D:light didn't recognize my USB-dmx EnttecPro (Red light again) but it worked when I reinstalled the enttec driver again
but I guess the korg driver's installation screwed up the winUSB driver.
that's unfortunately windows drivers business ...
if I understand well you use Mlink to deal with volume control of VLC.6) By the way, I use VLC to trigger a VLC list of music tracks with Slinks, but I have desisted of the Mlinks for volume control, I can't get it running perfectly, it kept giving me surprises on airshow, like keeping at zero and not fading in until FF...
There's something you should know about MLinks in
:Light, as long as you don't touch Submasters with midi fader or whatever, MLinks will control them.But if you touch Submasters with Midi faders or whatever, DL will not process MLinks for them anymore as long as MLink target != Submasters level.
The choice of this design is:
if the user haver decided to take manually control over the Submaster it'sd maybe because there is a problem and in case there's a problem, do not process them.
Hope it's clear and helpful
