d light et led
il y a 5 ans 11 mois #20923 par lobelzar
d light et led a été créé par lobelzar
Hello everyone I wonder if D light is good for managing a led light park. I only have par64 and other led projector thank you for your answer
il y a 5 ans 11 mois #20924 par sl1200mk2
Réponse de sl1200mk2 sur le sujet d light et led
Hi,
this is just my point of view... DL is good to manage let's say 10-30 devices park but when you go > 30 devices, you better use a dedicated harwdware like grandMA.
it's not it's impossible to use more than 30 devices in DL but the more you'll load devices, the more the graphicals updates will be slow.
for example, you can load DL with 100 devices, as long as you only work on groups of 20 devices (selected devices I mean) it'll be fast. If you select all the 100 devices it will be slow.
Also, design of the software is mainly for theater use, if you want to do gigs you better use grandMA.
Les utilisateur(s) suivant ont remercié: lobelzar
il y a 5 ans 11 mois #20925 par lobelzar
Réponse de lobelzar sur le sujet d light et led
It's not easy to find simple, inexpensive lighting software. I would like to move on to something other than Freestyler that I currently use Do you have an idea?
Temps de génération de la page : 0.117 secondes
