All scenes are played after each other BUGG??
il y a 7 ans 7 mois #18366 par SoundSurfer
All scenes are played after each other BUGG?? a été créé par SoundSurfer
Hey Nico,
First of all, i appreciate all the work you are doing for all of us!
I have a show on friday, that i havent done in about a year. The file was made with an earlier version of dlight. I dont know why, but when you "go" the first cue, with spacebar, or with an MSC GO via qlab, all the scenes will play after each other, as if the fade out time is like a follow.
the files is attached. hope you can help...
Fichier en pièce jointe :
Nom du fichier : SIRENENU.sho
Taille du ficher :27.13 Ko
Jannes
il y a 7 ans 7 mois #18367 par sl1200mk2
Réponse de sl1200mk2 sur le sujet All scenes are played after each other BUGG??
Hi,
it's not a bug...
at some point, I've reduced minimum timing to 0second (instead of 0.1s) but ancient sho are recorded with 0second for the WAIT time, and thus, they're now displayed with 0second which is equal to autogo for each step...
the solution is:
open the Sequence window
each time you don't want autogo, select the step, be sure command line is empty and press 'w' (Wait shortcut)
hope it's clear.
Les utilisateur(s) suivant ont remercié: Emanresu
il y a 7 ans 7 mois #18368 par SoundSurfer
Réponse de SoundSurfer sur le sujet All scenes are played after each other BUGG??
Ok, i think i found the problem. The newer version of dlight works with a dot (.) instead of a 0 for the values in the sequences. so old version had a 0, therefor all the cues were following in 0.
cheers!
Jannes
il y a 7 ans 7 mois #18369 par SoundSurfer
i just figured it out. but still thanks anyway. its easier to double click in on the 0's in the sequence window, they will turn into dots. Thats is way quicker.
ps looking forward to name channels in the patch window!! ;-)
cya soon!
il y a 7 ans 7 mois #18370 par sl1200mk2
yeah I know :)
Temps de génération de la page : 0.127 secondes
