devices
il y a 8 ans 8 mois - il y a 8 ans 8 mois #16318 par lewisinheaven
devices a été créé par lewisinheaven
Hi, My french isnt that good; so in english. I'm a newby in working with RGB LED. Tomorrow I have to work with the CHauvet COLORado 1 Solo.
www.chauvetprofessional.com/wp-content/u...o_DMX_EN_Rev1_WO.pdf
Actually I want to control them old-school with static color and zoom. Nothing fancy, only the dimmer level changes in my cues. What is the most simple way to do this? Where can I find more info on creating a device and creating palettes. The Wiki is in french and not so comprehensive to me.
Specific questions I have regarding making a 9ch personality for the COLRado 1 solo in SSP mode:
1.how do I enter the Zoom parameter that the COLORade needs in the device personality editor?
2 what does the home column mean?
thanks in advance Ruben
il y a 8 ans 8 mois #16321 par sl1200mk2
Réponse de sl1200mk2 sur le sujet devices
the whole process for using devices in DL is:
-create or write personality (Personality Editor)
-load personality in your .sho (Device Listing)
-set a 'channel' for the device (Device Listing)
-patch it (Patch)
-record Palette of colours or focus or whatever (Device Commands)
after that in the main window, you set a palette to a device, you give an intensity to the device and you hit Record (R shortcut).
DL will record a DeviceLink which contains palette reference.
this is the device mode, it's not very complicated.
so, following the DMX chart of your device, you first need to choose which mode you wanna use.
following your needs, I would say the SSP mode.
in TOUR mode, you'll need to patch 9 channels (once again, this is the ooooold fashion style).
In that case, ch1 will control the dimmer, ch2 = Red, etc...
if you work like that, you'll want to record cue as each parameters of your device is a dimmer
you can use google translate or another service to translate it
you add an offset, you set attribute to BEAM and set the PARAMETER to zoom
HOME is like a reset.
when you start creating a Palette, it's a good thing to set your device first at HOME, like that there's no colours (if HOME is 0 for colours) shutter is open (according to the dmx chart, if HOME is set to HOME position, etc...).
il y a 8 ans 8 mois #16322 par lewisinheaven
Réponse de lewisinheaven sur le sujet devices
merci pour l'aide!
it's kind of working in SSP mode now.
only thing is that record is not always working. I have too practice a bit I guess. For some channels, after record nothing happens. And I managed to record 8 channels so I have to find out what I'm doing wrong here.
il y a 8 ans 8 mois #16323 par sl1200mk2
Channels need to have a level for DLink to be recorded.
If they don't have a level, you can still use Force DLink option.
il y a 8 ans 8 mois #16324 par sl1200mk2
Temps de génération de la page : 0.132 secondes
