[RESOLU] plantage version 4.0.14
- claireloy34
je dois faire une passation de regie sur un mac book 10.6.8 comme le mien mais un autre, et la derniere version plante (ferme) a l'ouverture de d::light.
Une solution urgente pour Avignon qui commence demain ?
Merci !
Claire
- claireloy34
- claireloy34
- claireloy34
Process: X11.bin [1028]
Path: /Users/Lune/Desktop/XQuartz.app/Contents/MacOS/X11
Identifier: org.macosforge.xquartz.X11
Version: ??? (???)
Code Type: X86-64 (Native)
Parent Process: launchd [103]
Date/Time: 2017-07-07 02:57:08.282 +0200
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6
Interval Since Last Report: 2054912 sec
Crashes Since Last Report: 99
Per-App Crashes Since Last Report: 17
Anonymous UUID: E60F6040-0A19-4A4C-A404-0EE74D7E2C85
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Crashed Thread: 0
Dyld Error Message:
Library not loaded: /opt/X11/lib/libAppleWM.7.dylib
Referenced from: /Users/Lune/Desktop/XQuartz.app/Contents/MacOS/X11.bin
Reason: image not found
Binary Images:
0x7fff5fc00000 - 0x7fff5fc3be0f dyld 132.1 (???) <29DECB19-0193-2575-D838-CF743F0400B2> /usr/lib/dyld
Model: MacBookPro5,5, BootROM MBP55.00AC.B03, 2 processors, Intel Core 2 Duo, 2.26 GHz, 2 GB, SMC 1.47f2
Graphics: NVIDIA GeForce 9400M, NVIDIA GeForce 9400M, PCI, 256 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8D), Broadcom BCM43xx 1.0 (5.10.131.42.4)
Bluetooth: Version 2.4.5f3, 2 service, 12 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Serial ATA Device: TOSHIBA MK1655GSXF, 149,05 GB
Serial ATA Device: MATSHITADVD-R UJ-868
USB Device: Built-in iSight, 0x05ac (Apple Inc.), 0x8507, 0x24400000 / 2
USB Device: Internal Memory Card Reader, 0x05ac (Apple Inc.), 0x8403, 0x26500000 / 2
USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0x06100000 / 2
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8213, 0x06110000 / 4
USB Device: Apple Internal Keyboard / Trackpad, 0x05ac (Apple Inc.), 0x0237, 0x04600000 / 3
USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8242, 0x04500000 / 2
- got
- Remerciements reçus 44
Quel est la version de xquartz que tu utilise ? et la version de DLight (est ce bien celle marqué DL_4.0.14_MacOSX6_MacOSX7) ?
Les vielles versions sont dispo ici
www.xquartz.org/releases/index.html
mais pour DL 4.0.14 il faut xquartz 2.7.11 (mais je crois que la 2.7.9 marche aussi, enfin c'est le cas chez moi, mais l'ouverture de DL est assez longue du coup, et la 2.7.11 fixe certains bug)
- Remerciements reçus 1084
comme te l'as indiqué Got, DL est compilé avec la derniere version de XQuartz, la 2.7.11.
XQuartz fonctionne avec 10.6.3, mais DL avec 10.6.8 minimum.
du coup fais bien gaffe à la version de l'OS.
ensuite, t'as bien redémarré l'ordi après l'install de xquartz?
- claireloy34
Merci GOT.
Nico j'ai la derniere version de x quartz et la derniere version de d::light sur un mac 10.6.8
Ca devrait fonctionner...Mais maintenant quand j'allume d::light il me demande ou trouver x quartz alors qu'il est dans les applications...J'ai bien redemarrer l'ordi.
Il faut que je le range ou x quartz pour que d::light l'utilise automatiquement a l'ouverture ?
ce que tu télécharges depuis le site d'xquartz, c'est un .pkg.
t'as bien double cliqué dessus pour l'installer dis moi?
- claireloy34
- claireloy34
- claireloy34
