triggered stopwatch
il y a 11 ans 9 mois #9296 par birt
triggered stopwatch a été créé par birt
i need to start and reset a stopwatch during a performance and i want to do this with dlight
is there a way to do this with the built-in stopwatch? (it is very small though) or can this be triggered/reset with a shortcut that i can press at the same time as the cue that needs to start it?
i tried to find a stopwatch that can be triggered with OSC or MIDI but i haven't been succesful yet.
any ideas?
il y a 11 ans 9 mois #9303 par sl1200mk2
Réponse de sl1200mk2 sur le sujet triggered stopwatch
did you give a shot to Midi TimeCode?
il y a 11 ans 9 mois #9304 par birt
Réponse de birt sur le sujet triggered stopwatch
no i didn't really understand how that works. it looked to me like a way to trigger cues on certain times. i don't need to do that. i need to have a stopwatch for the dancers that gets reset at certain cues.
il y a 11 ans 9 mois #9329 par fIfOU
Réponse de fIfOU sur le sujet triggered stopwatch
Hello Birt,
Did you solve your problem ?
Are you on mac or PC ?
il y a 11 ans 9 mois #9373 par birt
i am on mac.
i used a simple app called "pace clock"
when the clock needed to be reset i pressed go on my Nanokontrol and R on the keyboard (to reset that clock) at the same time. it's not connected but it did the job.
i tried to put the clock on an external screen but it seems Dlight doesn't like external screens. the main window was still open but i couldn't see it on any of the screens until i disconnected the external again.
il y a 11 ans 9 mois - il y a 11 ans 9 mois #9377 par fIfOU
Hi Birt,
I have a little patch that should suits you.
A timer triggered in OSC by D::Light. You can Run, Pause, Reset timer with Subs n°21, 22, 23.
You can even add these triggers in your cue list with MLinks.
It runs under Isadora. (video software not really made for that, but it works well)
Download Isadora v1.3.1f06 (fully endless functionnal demo - No save) here :
troikatronix.com/download/isadora-download/
and open attached patch.
In D::Light setup, add an OSC writer :
IP Address : Localhost
Port : 1234
Activate OSC by clicking the OFF red led to green.
and you're done.
Hope it helps.
Don't forget to donate to D::Light if your show goes on tour..
Best
Philippe
il y a 11 ans 2 mois #10665 par dylan
Réponse de dylan sur le sujet Chronometre-timer.
est il possible de mettre un chronomètre ou timer sur dlight qui démarrerai à un certain go. Histoire d'avoir une timeline de mon show.
J'aimerais un chrono sur un deuxième écran.
est ce possible?
D'avance merci
il y a 11 ans 2 mois #10681 par fIfOU
Réponse de fIfOU sur le sujet Chronometre-timer.
Hello
Tu est sous Mac ou pc ?
il y a 11 ans 2 mois #10683 par dylan
Sous PC… Linux
il y a 11 ans 2 mois #10684 par fIfOU
Dommage, j'avais un truc sous mac..
il y a 11 ans 2 mois #10685 par dylan
Ca m'intéresse :-)
il y a 11 ans 2 mois - il y a 11 ans 2 mois #10686 par aroom
Réponse de aroom sur le sujet Chronometre-timer.
par ici les brocolis : getdlight.com/index.php/en/forum/1-gener...gered-stopwatch#9377
merci à l'onglet recherche ;)
au passage, j'ai fusionné les 2 articles
il y a 11 ans 2 mois #10688 par fIfOU
Ah oui,
Merci aroom,
j'avais oublié que j'avais déjà balancé le patch du timer OSC sur le forum !
Philippe
il y a 11 ans 2 mois #10689 par aroom
par contre, la pièce jointe a disparu. est-ce que tu pourrais la reposter stp ?
il y a 11 ans 2 mois #10690 par fIfOU
Hop !
Les utilisateur(s) suivant ont remercié: aroom
Temps de génération de la page : 0.226 secondes
