D Light pour MAC
- luiananda
il y a 9 ans 8 mois #14447
par luiananda
Réponse de luiananda sur le sujet D Light pour MAC
Mac System OSX Sierra, Dlight 4.0.0_b47 it work well with xquartz 2.7.7, but not with the last DLight version they do not open up...and with the last xquartz 2.11 also does not work....
regards, Luigi
regards, Luigi
- Remerciements reçus 1084
il y a 9 ans 8 mois #14448
Réponse de sl1200mk2 sur le sujet D Light pour MAC
Les utilisateur(s) suivant ont remercié: luiananda
- luiananda
il y a 9 ans 8 mois #14449
par luiananda
So I installed the xquartz 2.7.11 and now the new version are working also the trial version, I could open, tested, seems all fine, but now the previous version the b47 does not open, there is something that I would like to try but I have been unsucceeded with the Luz app it say DLight send a wrong IP, there is some instruction....
Thanks for your effort and Job, I have send many new customers
Regards, Luigi
Regards, Luigi
il y a 9 ans 8 mois #14452
@luigi
ah ok.
I'm glad to hear new DL works on your Mac.
for
:Luz:
you should switch off you wifi, restart DL, start the OSC server of DL (like that it will handle the wired card address for it's base IP).
in DLuz, you should write/request that IP as DL's destination
ah ok.
for
:Luz:you should switch off you wifi, restart DL, start the OSC server of DL (like that it will handle the wired card address for it's base IP).
- luiananda
il y a 9 ans 8 mois #14459
par luiananda
Yes with Dluz I was see that it was busy too many address, so I will try again with no wifi...
about the trial version how to switch in full....now I have been back with xquartz 2.7.7 and using the dlight version 4.7.b47 which work very well
Thanks, Regards, Luigi
Temps de génération de la page : 0.162 secondes
