Shortcuts
il y a 12 ans 11 mois #7438 par snarf36
Shortcuts a été créé par snarf36
Hi Nico,
I am using a numeric keypad for quick input for channels and patching with my laptop.
My old numpad broke down and now with a new one or a external mac keyboard the enter command does not work anymore.
Is it possible to add ENTER in the shortcut list? or add KP_Enter as an action input?
Maybe KP_1 for 1 and vice versa?
il y a 12 ans 11 mois #7439 par sl1200mk2
Réponse de sl1200mk2 sur le sujet Shortcuts
Hi,
This is exactly the purpose of the double columns in the shortcuts window.
Open the shortcuts window, put the cursor on the validate command in the second column, hit the enter key on your keypad, you should see KP_Enter, then validate with ENTER on your computer keyboard.
Doing this you should be able to use your external keypad.
Do the same for numbers or whatever....
il y a 12 ans 11 mois #7440 par snarf36
Réponse de snarf36 sur le sujet Shortcuts
Yes I know how that works,I use it all the time, but the reason I write this is that ENTER is not in the shortcut window
il y a 12 ans 11 mois #7441 par sl1200mk2
Does a validate command exists?
If you create a new sho, does the ENTER shortcuts appears for any command?
il y a 12 ans 11 mois #7444 par snarf36
I should say a validate command like Enter should exist because it can be written in macro's.
And no, Enter shortcut does not appear in the shortcut window in a new show.
It never did but I used a numeric key pad before that had the enter as a genuine enter command.
The one I now use outputs KP_ENTER.
il y a 12 ans 11 mois #7446 par sl1200mk2
k, I'll double the ENTER command with KP_Enter in the next release.
Thanx for noticing that.
Can you please post in the 3.0.20 release thread for me not to forgot.
il y a 12 ans 10 mois #7541 par sl1200mk2
Hi,
I've published a second beta before the next release.
in this one you can use any key to map to Enter function.
can you please test and report?
il y a 12 ans 10 mois #7543 par snarf36
Works!
Thanks Nico.
il y a 12 ans 10 mois #7544 par sl1200mk2
thanx,
enjoy!!
Temps de génération de la page : 0.148 secondes
