- Remerciements reçus 5
No Shortcuts in Linux!?!?
- dFVarela
Got an old LapTop and decided to make a small instalation of Linux in order to have a dedicated OS to run DLight, to achieve that i've decided to install a command line Ubuntu, FluxBox window manager and all the other things i needed to make DLight run (libXss,alsa,etc).
After that gave my user the permissions needed to acess USB and MIDI, almost everything worked out of the box (still having some problems with mounting CD & USB PenDrives), but what's really killing me is that when i launch DL with SUDO it all goes well, with the obvious exception that OLA Server doesn't start, but when lauched as a regular user there aren't no Shortcuts and i'm not able to create my own!
Does anyone have a solution? It's for sure a matter of User permission... But which one?
It would be great if anyone could help me!
Thank you all in advance!
dFVarela
- Remerciements reçus 1084
how did you install the libxml2?
does it belongs to USER group? because writing shortcuts (among almost everything) rely on libxml2.
after for the OLA stuff, it would be great if you report more errors in order to improve the mechanism.
- dFVarela
The only package i needed to instal in order to get DL running was libxss1, and alsa to get the midi working and add my user to audio group to access MIDI.
What is the group i should add my user in order to access Libxml? (I'm sure that will solve the problem!)
Regarding OLA, is not a error:
( www.opendmx.net/index.php/Using_OLA )How to start olad
For testing run olad in non-forking, log to stdout, debug level 3:
olad -l 3
olad refuses to run as root.
As soon i fix the libxml problem, or other i'll be playing around with OLA and if any errors appears i'll tell you!
Thanks!
Daniel Varela
dFVarela
does this happen only with shotcuts?
if yes, it's not a libxml2 issue. if it were, you will not be able to have midi binding, neither any kind of cue or whatever.
there's is a tricky bug with shortcut window (that is fixed in the upcomming beta) that prevent to record any shortcut once you hit the 'Tab' button.
also did you do:
sudo apt-get install xorg-devel
- dFVarela
I can connect MIDI controls but when exiting i got errors and the MIDI commands are lost!
I didn't install xorg-dev but installing it didn't solve the problem!
It must be a user permission problem because running:
dFVarela
example (just to show you the PATH
sh /home/users/daniel/Desktop/DL/DL.sh
- dFVarela
It is the same.... I got DL error :
Shortcut doesn't exist!
And the same 30 I/O error!
Can someone on linux issue this on a terminal and tell me what grops they belong to?
dFVarela
DL relies on the user HOME variable.
what's the result of :
echo "$HOME"
- dFVarela
No my user name is:dlight
and the result is:
/home/dlight!
dFVarela
- dFVarela
/home/dlight/DLight-32-Linux/
dFVarela
export PATH=${PATH}:/home/dlight/DLight-32-Linux/bin
and launch DL again.
- dFVarela
dFVarela
at launch DL attempt to create a .DLightWorkingSho folder in the $HOME directory.
so in your case, that mean in /home/daniel/.DlightWorkingSho
if you display hidden files, do you see this folder?
does it have read/write permissions?
