- Remerciements reçus 1
Crash on OSX
- vbs
This weekend i had 3 time's in a role a crash with D-Licht 3.0.15
First time by refreshing the midi controller in the setup menu (the USB cable had bin dis connected)
Same thing for the Entecc controller turn the green light off and on then the crash happend.
Third time on the midi controller (Beriinger) i closed two sub-masters at the same time.
Earlier that week i also had a crash using the Iphone true Touch-OSC on d-light.
If the dlicht desk is in RPN mode and i press Channel on the Iphone Dlight crashed.
Later i tried al the same things again and no crash happened.
Some time this make's me little annoying if i have to play life in a play!!!! :sick:
Is there a way to find a crash report some where in the system.
Vincent
- Remerciements reçus 1084
yes, here's where they are located on my computer:Is there a way to find a crash report some where in the system.
/Users/nico/Library/Logs/DiagnosticReports/DLight_2013-05-13-100050_brouhaha.crash
can you please make .zip of the .crash and post them here?
are these bugs are reproductible?
did you found the logs?
- vbs
I am running on OSX 10.8
I send you the crash report.
The problem:
Happened on 12-05-13
The problem:
Happened on 6&7-05-13
I hope you can find something in the crash report.
Best regards Vincent.
thanx for that, I'll have a look at them.
this one is the one that worry me...Third time on the midi controller (Beriinger) i closed two sub-masters at the same time.
is it reproductible?
did it happened when you only display used channel in the workspace?
do it happen when you display all the channels?
do u use the command 'only display active submasters' when this crash happen?
- vbs
* I don't remember if i did but there is a possibility
do u use the command 'only display active submasters' when this crash happen? I don,t understand your question
it should fix the most worrying bug, but I didn't work on the two others
you can tell DL to display only submasters that have a level.do u use the command 'only display active submasters' when this crash happen? I don,t understand your question
under the 'RLink' button, press the little blue square to switch submaster's display mode.
