Add point steps ??
il y a 14 ans 4 mois #4967 par vbs
Add point steps ?? a été créé par vbs
Hi
Is it somehow possible to ad point steps to Dlight.
Right now if you program a show and you put the description in a written quelist, you have a problem if you add a insert in the steps.
You have to renumber al you que steps in your list.
A point step to ad should be very easy instead 10 be come,s 11 it will be 10.1
May this be as suggestion if other people would think this is a advantage.
Regards Vincent
il y a 14 ans 4 mois #4970 par sl1200mk2
Réponse de sl1200mk2 sur le sujet Add point steps ??
Hi Vincent,
in short, no!
but why don't you work with floating point cues?
and what if you put description not to the cueList, but to the steps?
and what is your problem when you insert a step?
step numbers are just an ordering count. If you work you floating cues, they automatically insert in the good place (incremental order)
you can record cue 1, after cue 1.01, after 1.015, after 1.0169, after 1.02, etc...
Temps de génération de la page : 0.136 secondes
