allocate memory
il y a 14 ans 4 mois #4923 par paucurses
allocate memory a été créé par paucurses
Hello
I have a dupte - It is possible to load a memory? This should come when you go to GO ... A similar function would be: allocate the cross-fader, the go (in LT)
I hope to answer. thank you
il y a 14 ans 4 mois #4926 par sl1200mk2
Réponse de sl1200mk2 sur le sujet Re: allocate memory
hi,
it's not very clear for me what you ask...
but there's a shortcut called 'cue_goto' you should have a look
select preparation Registre (the green one) use 'cue_goto' to load your cue and press GO.
hope this helps.
il y a 14 ans 4 mois #4927 par paucurses
Réponse de paucurses sur le sujet Re: allocate memory
Thank you! Is that! A perfect application!
Temps de génération de la page : 0.120 secondes
